underslung spare wheel
Postby dcurzon » Mon Jun 12, 2006 7:31 pm
i've got no way of getting it removed, i'd prefer to have it in the back rather than underneath anyway.
Anyone in Cheshunt with the tool for undoing these things?? or is there an alternative method??
ta :)
dcurzon
Postby MarkM » Mon Jun 12, 2006 7:35 pm
Depends which model Transit it is for which tool you use. Smileys use the jack handle through the rear panel above the bumper and the earlier ones use whatever sized socket you need through the floor from the inside. Both can sieze up, the cable drop version can be cut off and the bar clamp version can be removed.
MarkM
Postby dcurzon » Mon Jun 12, 2006 7:40 pm
ah, its a mark 5, but i dont have the jack handle. or the jack. so i'm pretty screwed if i get a puncture! :D
how deep is the bit that the jack handle needs to undo? wonder if i can get a 19mm socket down there
dcurzon
Postby MarkM » Mon Jun 12, 2006 7:49 pm
From the back to the unit is around 15 inches or so, you have to push when you are doing it so you might be able to get a socket on a long extension bar to do it but the clearence with the bumper is not the same size as even with a 3/8th socket so you 'may' get the socket in but you also stand a very good chance of dropping the socket into the wheel, find someone with a Ford jack complete. I don't know what size the socket needs to be probably a 14mm knowing Fords but it isn't a 19mm.
This is the only time I have ever had to use the Ford item as my older Transits all had the clamp bar arrangement...much better and I would never use the Ford jack on a Transit as I simply do not trust it, so this is why I carry a trolley jack.
MarkM
Postby MrMPuk » Mon Jun 12, 2006 8:47 pm
It's not the same shape as a nut but you may be able to jam a socket on it.
Postby motorwise » Mon Jun 12, 2006 9:17 pm
it's an internal square - about three quarter drive sort of size - I can't measure mine the one on my old van because I sold it yesterday (bad luck :wink: )
have you not got the tools with yours then? - the drive is on the end of the jack handle - have a look at the jack and measure the square hole in the drive on that
http://www.motorwise.net
motorwise
Postby 100ps_drw_hicube » Mon Jun 12, 2006 9:21 pm
some are square drive and some are square drive with hex in end :? :? which do you have???
100ps_drw_hicube
Transit Abuser!!
Postby WINDSCREENGUY » Mon Jun 12, 2006 10:15 pm
cheshunt? im very very close
formally grey van man.
2010 115 semi high mwb . Fully loaded.
WINDSCREENGUY
previously grey van man
Postby rslsys » Mon Jun 12, 2006 10:41 pm
I use a "fit anything including Knackered nuts" socket on a long bar. The socket is full of spring-loaded pins and will adapt to just about any shape of nut. I gave a fiver for it at an autojumble a while ago and it has proved a lifesaver. I have the added complication of a beavertail on the back of my trannie so its a lay-on-the-floor job to get the spare out!
rslsys
Postby fitzy » Mon Jun 12, 2006 11:11 pm
I bought a new handle from Fords two weeks ago for £20. Fords only use one type of handle/winder bar for the smiley shape vans, as it only shows one handle on their Microcat system for the whole of the smiley range from when they first built the mk5 right up until the new mk6 came out.
The carrier on my 1997 "P" had the nut rounded off ny previous owner, so got a replacement of an "X" reg at my local breakers yard. Only difference between them was that the newer carriers don't utilise the hook arrangement to secure the clamp anymore (Ford deleted this arrangement because of improper raising of the wheel, sfaety reasons etc). The size of the nut on both carriers is 15mm (same on the handle), parts man at Fords said that this was the only size of nut used on all the smiley mk5 carriers.
At £20 i thought it was a bargain as it saves space in the back and stops my stock getting damaged as the wheel had to be stood up and kept falling back and forth as i drove, therefore crushing my stock.
HTH
Fitzy
fitzy
Postby 100ps_drw_hicube » Mon Jun 12, 2006 11:15 pm
fitzy wrote:I bought a new handle from Fords two weeks ago for £20. Fords only use one type of handle/winder bar for the smiley shape vans, as it only shows one handle on their Microcat system for the whole of the smiley range from when they first built the mk5 right up until the new mk6 came out.
HTH
Fitzy
my ford dealers list 2 one as discontinued as it were crap then the revised item :D thats a lot better imo!!! expensive tho
100ps_drw_hicube
Transit Abuser!!
Postby MrMPuk » Mon Jun 12, 2006 11:15 pm
I must say that your Ford man knows nothing becasue as we have proved there are more than one type used on the smiley vans!
Postby 100ps_drw_hicube » Mon Jun 12, 2006 11:18 pm
exactly!! tho the revised item listed at my dealers is very similar to a mk6 item tho not the same :D
100ps_drw_hicube
Transit Abuser!!
Postby MWOOLY10 » Tue Jun 13, 2006 12:35 am
I had that problem a while back..when i got a flat,it was only then i found out i didnt have a jack or handle or anything :lol: :oops:
If i remember rightly i think a 15mm socket with extension bars aided by a slight tap with a hammer and the nut will undo the wheel :)
Cheers Mike
MWOOLY10
Postby dcurzon » Tue Jun 13, 2006 9:54 am
grey van man wrote:cheshunt? im very very close
oooh, how close??? :D
dcurzon
