The van has had an intermittant problem starting latley, the starter solonoid has been firing but the starter doesnt run, after much twiddling we found if you tapped the solonoid while trying to start her the starter motor would run up. I`ve pulled the solonoid out and stripped it down, the problem appears to be the main contacts in the solonoid are badly worn, I cleaned them up with emery cloth to get rid of the burnt bits (cleaned everything else while I was at it), reassembled it and now the engine starts first turn of the key. My question is, are the contacts available from anywhere, as I dont see the point in buying a complete motor assembly when it just the contact blocks that are at fault.
Cheers guys.
Oh forgot to say its a 94` 2.5Di
