Hi
I have a smoking and starting problem with my 1998 T190 crewcab 135K.
Seemed to happen suddenly a few weekends ago shortly after filling up.
Symptoms are:
Excessive white/grey prehaps a little blue smoke on acceleration and idle.
Will only start when hot/warm. Can be started from cold if No.1 injector is bled while cranking over.
A local mechanic has reset the timing and injector timing and put a possible cause down
to inferior fuel after noticing that it was evaporating.
Engine doesn't use any oil or coolant.
Have replaced the fuel filter and filled up with fresh diesel and I'm running the van
hoping that the new fuel will circulate and reduce the smoking,if it is that.
Any help would be appreciated.
Dan
