Hi, I have just removed the rear bumper on my swb standard roof Mark 5 transit - it is completely rotten! Does anybody know if repair panels are available for these rear corners or do I have to fabricate my own?
Many thanks,
Will.
williamraff wrote:Thanks for the replies guysI am afraid it is more than a few holes
This van has been dissolving away steadily for the past fifteen years and its time to put some strength back in
My new welder ( clarke 151te) has just turned up and is about to be put to the test. I will be posting a picture log of before and after presently.
Cheers,Will.
williamraff wrote:I have heard good reports about the smaller gasless migs, if you are able to weld inside or in a sheltered position you should be ok. It should certainly be up to welding automotive grade mild steel so long as both surfaces are clean and grease free.
My welding is not pretty, that is why I bought the Clarke, I need all the help I can get![]()
I may just post the before pics for the moment and update as I progress.
Final tip - ebay and alcohol do not mixI should be out and about doing whatever it is men of my age are supposed to be doing
Instead I am going to weld a £300 transit back to life
"cest la vie"
