3 probs fixed, another one comes.. and bigger each time.
Now have fuel pissin out the Lucas Cav pump, getting bit sick of entire system, more leaks than a collinder, Lump now near refuses to start and cuts out a short time after firing up. Effectively no van at minute.
So, am toying with ideas, first of all, where the leak is from is it just a repairable seal on the shaft? Starting to consider the costing of buying another Lucas Cav pump, cost of fitting, on what is a tired engine is it really worth it, what will die next..... would it be more cost effective to buy a newer banana lump and have that fitted instead..
Have you guys upgraded a lump rather than continuing to battle against Lucas Cav pumps, or is it cost effective to switch to a bosch injector setup, bearing in mind I have to factor in labour costs, as not sure how to do such things.
Thanks again
andy
