Soddin rear brakes
Soddin rear brakes
Postby phoenix » Thu May 06, 2010 4:55 pm
Failed the MOT on OS rear brake showing little or no effort so put new shoes in both sides & took it for re-test, that side is now ok but the NS rear is now showing little or no effort. What's going on?
phoenix
Re: Soddin rear brakes
Postby topfuel » Thu May 06, 2010 5:04 pm
hi ! try bleeding the two rear cylinders, or replace them ! being as you have changed the rear shoes ,the cylinders will be set futher back in there bore's . so it't possible that there now sticking on the opposite side now !
topfuel
Postby MrMPuk » Thu May 06, 2010 5:06 pm
What were rear adjusters like?
Postby phoenix » Thu May 06, 2010 5:22 pm
Rear adjusters are like two bits with teeth on. Not quite sure how they work tho'.
phoenix
Postby darkbluevanman » Thu May 06, 2010 8:06 pm
I'll save you the effort Puk... :roll: :roll: :roll:
darkbluevanman
Postby MrMPuk » Thu May 06, 2010 8:39 pm
phoenix wrote:Rear adjusters are like two bits with teeth on. Not quite sure how they work tho'.
The problem sounds like it could be the nut that holds the wheel then.
Postby the_big_fact_hunt » Thu May 06, 2010 9:35 pm
what? the one holding the steering wheel?? :lol:
Solve the World food problem.......... Feed the homeless to the hungry
2012 115T350
the_big_fact_hunt
Postby phoenix » Thu May 06, 2010 10:19 pm
Ha bloody Ha ha. If I knew what I was looking for and what the problem was I wouldn't be asking for advice would I.
phoenix
Postby MrMPuk » Thu May 06, 2010 10:21 pm
Did you free up the auto adjusters and actually "service" the brakes or just replace the shoes?
Postby phoenix » Thu May 06, 2010 10:27 pm
As far as i could make out, the adjusters are attached to the shoe. So in this respect they were freed up i suppose. What happens after this i don't know. Am not a mechanical numpty but not familiar with drum brakes.
phoenix
Postby doughythevanman » Thu May 06, 2010 10:56 pm
strip off the shoes, wire brush the adjusters and the hub, check the actual cylinders for free movement and any leaks from the rubbers and if all is free and working put it all back together! :wink:
if the cylinders dont move freely take them out and clean them up. dont think many places do seal kits now so may need to find yourself a new / second hand one.
P reg SWB Semi high top
S reg LWB 190 Semi high top
Range Rover TD6
Volvo S80 D5
doughythevanman
Postby phoenix » Fri May 07, 2010 8:42 am
Cheers for that, i'll have another look in there tomoz.
Good news is it only needed some minor welding on the cills this year so it will soon be up & earning its living for another 12 months :D
phoenix
