Landrover wheels.... again!
Postby darkbluevanman » Sun Jun 27, 2010 9:18 pm
I've been tempted to go the landrover wheels (espec now my swb is jacked up slightly) but I have an idea rather than redrilling....
As the pcd on the landy wheels is 5x165 & transit is 5x160 I imagine the landy wheels nearly fit but would obviously leave the orig holes offset, my idea is to fit a laser cut ring of let's say 4mm steel with the correct transit PCD holes and taper over the orig landy holes and weld in place, this would do away with the drilling and the unsightly extra holes, a set can be had new (15") for a little over a ton, what do ya thinks?
Oh... are the landy bolts the same size??
darkbluevanman
Re: Landrover wheels.... again!
Postby Luke » Sun Jun 27, 2010 9:21 pm
should work but wouldn't the plate look a bit unsightly :?: and how would you centre the new plate :?: :D
Postby Luke » Sun Jun 27, 2010 9:22 pm
darkbluevanman wrote:Oh... are the landy bolts the same size??
nope 12mm on the transit 14mm on the landys :)
Postby darkbluevanman » Sun Jun 27, 2010 9:32 pm
Even better... that 2.5mm difference has just been eaten up without effort ;) .... unsightly?... noooo, not as unsightly as those redundant holes. remember it's mm perfect, a simple jig or even 5 bolts (self centering!) the ring could always have a smaller diameter hole in the centre too as this isn't critical...
darkbluevanman
Postby Luke » Sun Jun 27, 2010 9:43 pm
next problem.......... i dont think the face where the holes are is completly flat :? i'll have to have a closer look at some :D
and what about welding it on :?: you'd see the welds and that'd look unsightly :!: :D
Postby Luke » Sun Jun 27, 2010 9:47 pm
if your going to weld the wheels why not just weld up the old holes like martins done :?:
best pic i could find :|
Postby darkbluevanman » Sun Jun 27, 2010 10:05 pm
good point, but we're fabbers not engineers, rings and welding are free, drilling the wheels isn't ;).... are those landy wheels in the piccy?? the pcd looks quite outward on the flange (if you know what I mean?)
darkbluevanman
Postby Luke » Sun Jun 27, 2010 10:34 pm
no the ones in the pic were suzuki 410 with 139x5 pcd :D
Postby Luke » Sun Jun 27, 2010 10:38 pm
darkbluevanman wrote:good point, but we're fabbers not engineers, rings and welding are free, drilling the wheels isn't ;).... are those landy wheels in the piccy?? the pcd looks quite outward on the flange (if you know what I mean?)
ive got a jig to redrill the wheels - bolts up to the landy pcd and you just drill through 3mm holes which are 160pcd
i'd do em you but you could almost make a jig on the lazer - 5x165 holes 12mm and 5x160 3mm's then bolt it up with some old studs drill through the 3 mm with a pistol drill then go through a set of drills untill you get to the 13mm then all you need is a 60deg taper bit to put the nut seat on - piece of piss really :D
then weld the old holes up :lol:
Postby MinorMatt » Sun Jun 27, 2010 10:43 pm
Landys use 16mm bolts ;)
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby darkbluevanman » Mon Jun 28, 2010 6:54 pm
O.K, got ya... sound easy enough as you say, gonna order some and go for it.... going for the 15x7" for a better price in tyres, prolly 195/70/15's (poss 205) would suffice?
darkbluevanman
Postby AndyG » Mon Jun 28, 2010 7:21 pm
darkbluevanman wrote:O.K, got ya... sound easy enough as you say, gonna order some and go for it.... going for the 15x7" for a better price in tyres, prolly 195/70/15's (poss 205) would suffice?
You can go up to 225/70/15 on your MK5 :)
Postby darkbluevanman » Fri Jul 02, 2010 8:02 pm
Right, bought some new 15x7 8 spokes (landrover):
But now I have them I think they are to overkill fandango for me, I've borrowed a couple of pictures off the forum....
The look I want is like Alans white van, but with these wheels I'd end up with the look of the black one underneath, now I can see the difference in the rim offset ('thought' they were all the same!!!)... double bugger (after the leaf spring cock up, not going well).
courtesy of Luke
If anyone is remotely interested in these, they can be had for 90 quid (4 off) and I'll throw in a drilling jig to convert to Transit, or I'd swop for something less sticky out!
darkbluevanman
Postby Luke » Fri Jul 02, 2010 8:17 pm
have you tried them on the van :?: my pukka transit wellers were right in line with the edge of the wing :D
Postby darkbluevanman » Fri Jul 02, 2010 8:19 pm
Luke wrote:have you tried them on the van :?: my pukka transit wellers were right in line with the edge of the wing :D
I haven't, you can see it luke, I've measured 'em and they will look like the black 'un... only about an inch in it!
darkbluevanman
