hi my mk5 smiley minibus hazard switch has stopped working,was at side of road when i heard a noise from fusebox and just stopped working,fuse ok,indicators ok but when i put hazard switch on the indicators dont work,could this be a dodgy relay or faulty switch,any ideas,cheers glen
ye transit part centre is all gen ford parts from turkey they all do the same job anyway or if ya like me go to the scrappy ya can pocket it or get them for £5
They are allways going,ive changed loads of them ,sometimes if you put a left indicator on,and switch hazards on they will work,,...same with the washers ,the stalks give up the ghost £5 in Brum from transit breakers..best wishes Billy :
