Interior lights
Interior lights
Postby Guy88 » Sat Jul 08, 2006 10:15 pm
Got a problem with the MK5.
None of the interior lights in th back work :( the plug for the switch is hanging out the dash so i jumped the 2 wires on it and guess what nothing :(
Checked the continuity from the swith to the lights. nothing. found a fuse in the back on the first support after the bulkhead. no power there but it is connected to the lights with a orange/black wire. the other is an orange white but it not the one at the switch :?
the orange white at the switch is 12v from fuse 11
What i want to know is why there is a fuse in the middle of the roof :?: and where it should be connected to :?
Van is a 1999 MK5 SWB 120 ex BT
Heres where the fuse is :shock:
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby AndyG » Sat Jul 08, 2006 10:17 pm
Does the radio work :?:
(same source :D if it's like my old '96)
Postby Guy88 » Sat Jul 08, 2006 10:20 pm
Yep the fuse is fine in the box. got power to where the switch should be :D
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby AndyG » Sat Jul 08, 2006 10:21 pm
Switch on the side lights and try again :idea: :D
Postby Guy88 » Sat Jul 08, 2006 10:25 pm
Side lights on flicked the switch on the back lights. Nothing :(
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby AndyG » Sat Jul 08, 2006 10:27 pm
Being an exBT van, has it got any additional fuse panels :?: Otherwise you'll have to start stripping :shock: :lol: :lol: :lol: :lol:
Postby AndyG » Sat Jul 08, 2006 10:30 pm
Just thought :idea:
Are you jumping the correct two terminals :?: as there's four per plug :D
Postby Guy88 » Sat Jul 08, 2006 10:33 pm
2 big terminals on the plug.
The only other fuse i can find is the one in the back and this has one wire going off to the lights. put 12v to it they work :shock:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby AndyG » Sat Jul 08, 2006 10:39 pm
Have you got 12v at the front socket where the switch is missing :?:
Could this van of had a second battery that could have allowed the rear lights to stay on for long periods :?:
Postby Guy88 » Sat Jul 08, 2006 10:42 pm
On the orange/white where the switch is missing i have 12v. if i pull out fuse 11 it dropps off. No sign of a second battery but it has been blown over :?
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Guy88 » Sat Jul 08, 2006 10:43 pm
Just thought it cant have a second battery as the water tank is in the way :D
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby AndyG » Sat Jul 08, 2006 10:51 pm
Could that fuse be for a beacon :?: :idea: and it's missleading you :?: :(
:idea: On my '96 van the twin 21watt lamp assembly in the cargo area had a very poor/no earth :roll:
The earth is the metal strip touching the bottom of the two bulbs which is missleading and caused my fuse to blow, killed the radio then had a bit of bother with it's code :roll: :lol: :lol: :lol:
So the side of these bulbs in these lamp assemblies is positive :D :idea: Have a quick test :wink:
Postby Guy88 » Sat Jul 08, 2006 10:52 pm
I have took a wire from the battery to the fuse and the lights worked :?
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby AndyG » Sat Jul 08, 2006 10:56 pm
:oops: Forgot you said that :oops: You'll have to follow it back :!: there's a missing link which isn't standard Transit :(
Any other switches/holes :?:
Postby Guy88 » Sat Jul 08, 2006 10:58 pm
The switch in the dash is missing. the 2 in the lights work thats all i could find. are there any miltiplugs hidden anywhere :?:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
