brake vacuum pump ?
brake vacuum pump ?
Postby johnnieG » Tue Jul 11, 2006 4:55 pm
hi, today my brakes decided not to work, one min they are ok, the next brake pedal gone rock hard and i had difficulty stopping. i think it could be the brake vacuum pump, is there anyway of testing this pump (behind the alt.), and what is the lickely cause for its failure. thanks.
johnnieG
Postby 100ps_drw_hicube » Tue Jul 11, 2006 5:34 pm
poor maintanace :shock: yep not regular enough oil changes does it :( take it off and take it apart and see for your self they usually have self destructed :shock: :lol: :lol:
100ps_drw_hicube
Transit Abuser!!
Postby johnnieG » Tue Jul 11, 2006 8:49 pm
cheers, are they easy to replace & do they cost a lot......
johnnieG
Postby 100ps_drw_hicube » Tue Jul 11, 2006 10:29 pm
fairly easy to change but if i were you (past experience :roll: ) clean out all the oil lines to and from the pump :) not sure on cost frauds charge a lot i seem to remember we got a pattern one from transit part centre (suppliers section :) ) it was about £29 +p+p :D
100ps_drw_hicube
Transit Abuser!!
Postby 100ps_drw_hicube » Tue Jul 11, 2006 10:30 pm
does the pump get red hot within a few seconds from startup (cold) if so theres a blockage :wink:
100ps_drw_hicube
Transit Abuser!!
Postby johnnieG » Wed Jul 12, 2006 2:19 pm
the pumps warm/hot, also there is a faint whirring noise since it happend !
johnnieG
Postby 100ps_drw_hicube » Wed Jul 12, 2006 5:41 pm
defo sounds like its shot :( :( :(
100ps_drw_hicube
Transit Abuser!!
Re: brake vacuum pump ?
Postby tommyb » Fri Mar 19, 2010 9:42 am
YE SAME SIMPTOM HERE one minute fine next panic and odd wurling noise had a look and yes its fu$ked found oil in vacum pipe at throtel vacum pipe and the plastic sensor bit at right side of bulk head .i think i read some wer it can efect the power to?
tommyb
