Injection pump advance unit ?
Postby kapri » Sun Jul 23, 2006 10:11 am
I've been told that there is an advance unit within the injection pump on a 2.5di engine, a sort of 'snail cam within a cam 'type set up. Is there anyway of checking whether this is functioning correctly ?
Trying to arm myself with all the info to hit the engine and sort its problems over the next couple if days .
kapri
Postby Nighthawk » Sun Jul 23, 2006 1:06 pm
The external cam was only on the old lucas pumps, the bosch pumps used an internal hydraulic set up.
what engine/vaehicle is yours?
Transit.........Job done
Nighthawk
Postby kapri » Sun Jul 23, 2006 1:41 pm
I'm told the engine is 89 on -2.5di though when I was looking at one the other day the inlet tract looked different ? Mine is short with a central mounted tb whereas the other one had a bunch of bananas tract.
I spotted a 92 on casting code on the exhaust whilst grubbing about.
I was told it's an internal set up and may become clogged if the fuel filter isn't changed regularly?
kapri
Postby gemini » Sun Jul 23, 2006 3:02 pm
this is a lucas pump with external advance
this is a bosch
gemini
Postby kapri » Sun Jul 23, 2006 5:20 pm
Just checked, definitely the Bosch unit.
kapri
