diesel pump easy to fit???
Postby WINDSCREENGUY » Fri Aug 04, 2006 8:46 pm
as the title suggests is this easy?
formally grey van man.
2010 115 semi high mwb . Fully loaded.
WINDSCREENGUY
previously grey van man
Postby transitgeoff » Fri Aug 04, 2006 8:48 pm
no
transitgeoff
Postby gemini » Fri Aug 04, 2006 8:48 pm
can you change a timing belt, if so then yes
gemini
Postby motorwise » Fri Aug 04, 2006 8:52 pm
gemini wrote:can you change a timing belt, if so then yes
sounds about right :D
http://www.motorwise.net
motorwise
Postby WINDSCREENGUY » Fri Aug 04, 2006 9:12 pm
never changed one but seen it done do i just need the timing pegs
WINDSCREENGUY
Postby MrMPuk » Fri Aug 04, 2006 9:25 pm
Timing pegs help but that's not all you need, if you are unsure I really wouldn't attempt it.
Postby WINDSCREENGUY » Fri Aug 04, 2006 9:38 pm
f**k it ill give it a go
WINDSCREENGUY
Postby MrMPuk » Fri Aug 04, 2006 9:48 pm
That's what I like to hear! You got a haynes maunal?
Postby WINDSCREENGUY » Fri Aug 04, 2006 9:50 pm
yeah and a tis cd i think ive done a couple of head gaskets and some clutches so i think ill be ok who knows?
WINDSCREENGUY
Postby MrMPuk » Fri Aug 04, 2006 9:52 pm
grey van man wrote:i think ive done a couple of head gaskets and some clutches so i think ill be ok who knows?
You think!! :shock: Are you not sure?
Postby Nighthawk » Fri Aug 04, 2006 10:25 pm
the pump is a piece of p1$$ to change, if you have the right tools and can use your hands.
time the engine up
rip the pump off
build it up...and recode the rim if it's a second hand pump ;)
Transit.........Job done
Nighthawk
Postby WINDSCREENGUY » Fri Aug 04, 2006 10:28 pm
cant u just ripp off the pats bit and not have pats
WINDSCREENGUY
Postby Nighthawk » Fri Aug 04, 2006 10:32 pm
could do, but you'd have to do some electrical system to get rid of the rest of the system. Otherwise the starter won't work :D
Nighthawk
Postby AndyG » Sat Aug 05, 2006 1:12 am
Nighthawk wrote: recode the rim if it's a second hand pump ;)
Please clarify :!: :? :? :?
Are the pumps coded :?:
Postby WINDSCREENGUY » Sat Aug 05, 2006 1:26 am
and when you say time the engine i take it you mean lock it with the pins?
WINDSCREENGUY
