Got oil in the inlet pipe between turbo and inlet manifold, does this mean turbo seals on the way out as i suspect
It doesn't seem to be causing much (if any) smoke from the exhaust, and power seems okay, but the inside of the inlet pipe is wet with oil, is there anything else that could cause this, or am I grasping at straws
Cheers
Alex
