turbo engine swop??are they the same
Postby tonyxno1 » Wed Sep 13, 2006 6:08 pm
ok heres my problem tourneo 2.5 td auto seized solid n i mean cooked 95 .ive got 2.5 diesal out my twin wheel which is a peach lump fast as fook 92
the td is epic system . can i just swop all bits over from one to the other ? are they both them same or will i find differance cos i hate get half way fitting n find they differnt castings
is there a differance in the td to normal aspirated engine build ie rings ?
thanks any help lads
tonyxno1
Postby MrMPuk » Wed Sep 13, 2006 6:14 pm
They are essentially the same block but the turbo lumps are apparently of a lower compression. I don't think you are going to get a definitive answer as i'm not sure if anyone has tried bolting everything from a 95 turbo lump onto a 92 Di.
Postby motorwise » Wed Sep 13, 2006 6:25 pm
I'd go for it - there's only a small difference in compression ratios between the two engines (20.6:1 as opposed to 18.3:1) just use the block and head and bolt all your ancillaries on (including injectors) - I would guess it'll be a shade quicker than it was before as well :D
http://www.motorwise.net
motorwise
Postby tonyxno1 » Wed Sep 13, 2006 7:16 pm
ok thas it then its full gender swop on 2.5 n full monty on td
she will look pretty with turbo 2nd question where u guys buy gaskets n shell bearings in london my local stockist south london pistons seems disapeared
tonyxno1
Postby MrMPuk » Wed Sep 13, 2006 7:16 pm
Motorfactors
Postby motorwise » Wed Sep 13, 2006 7:17 pm
tonyxno1 wrote:ok thas it then its full gender swop on 2.5 n full monty on td
find a factor that deals with ferrari pistons in charlton (they only deal with factors apparently) where are you based? I'll put you on to someone
motorwise
Postby tonyxno1 » Wed Sep 13, 2006 10:02 pm
im in bermonsey i know most local garages n factors cos we add breakers / garage/ tyre shop ten yrs but any help allways welcome
still it all got wait week off isle wight see classic car show on 16 17 sept was good last year i will take my other tourneo she runs like dream
cheers
tonyxno1
Postby kapri » Wed Sep 13, 2006 10:52 pm
Tony, I'll be at the IOW on 16th along with about 30 other 'different ' vehicles. You'll have to look hard to find my highly modified Transit !! It'll be satin black and rust coloured. :lol:
kapri
