94 2.0 (carb) cambelt change
Postby GTD. » Mon Sep 18, 2006 4:07 pm
The 2.0 petrol isn't covered in the haynes manual
Van came with new belt in glovebox and just ordered tensioner
whats the crack?
Cheers
Si
GTD.
Postby Luke » Mon Sep 18, 2006 7:07 pm
which 2.0 petrol DOHC or pinto :?:
Postby MrMPuk » Mon Sep 18, 2006 7:08 pm
Is the DOHC not EFI?
Postby madmark » Mon Sep 18, 2006 7:09 pm
:? on a 94 should be a pinto :? the carbs are abit of a strange setup on them they are like a twinchoke weber but with allsorts of pipes and gadgets all over them! :(
Postby Luke » Mon Sep 18, 2006 7:20 pm
MrMPuk wrote:Is the DOHC not EFI?
oh yeah didnt see that :roll: :lol:
cambelt change hmmm pritty strait forward if i remember right, no special tools - well ive never used any :? line the camshaft up with a mark on the head at bottom and off you go :lol:
Postby Guy88 » Mon Sep 18, 2006 8:42 pm
Once you line up the camshaft mark all the others with tipex incase you knock it.
crank has mark on. if you remove dissy cap, rotor arm and dust cap there it a scribe mark on the rim to line the rotor up to :wink:
You can use all the marks as they are its just easier to hilight them so you can find them. unlike what i did :roll: :roll: :oops:
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
