MrMPuk wrote::? What was the actual advisory?
MrMPuk wrote:So it's a rusty chassis then.
Luke wrote:i wouldnt bother doing all the bushes some last for ever and are a right pain to do - if you do want to give it a refirb do the strut top mounts and btm ball joints should be about £60-80![]()
but the advisory is a welding job
MrMPuk wrote:Start what one again?
75psT330lwb wrote:the advisory u mentioned refers to the area that the subframe bolts to so it would mean a rusty chassis. if ur going to do it then remove all the subframe, weld both sides up while ur at it, then do whatever it was u want to do to the subframe while its off.
MrMPuk wrote:75psT330lwb wrote:the advisory u mentioned refers to the area that the subframe bolts to so it would mean a rusty chassis. if ur going to do it then remove all the subframe, weld both sides up while ur at it, then do whatever it was u want to do to the subframe while its off.
Exactly, a rusty chassis.
