Mk7 radio pin out and rear speakers
Postby Punto443 » Sat Sep 10, 2016 10:01 pm
Asked a lot so here's the pin out and where to find the rear speaker wires for adding rears.
Also be aware that if using the base model radio, the rear outputs will work, but will not be controllable using the fader control until enabled in the vehicle configuration by diagnostics.
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Re: Mk7 radio pin out and rear speakers
Postby loot » Sat Sep 10, 2016 10:29 pm
My rear speakers had wires and plugs fitted to the van but they terminated at the big white connectors at the A pillars :roll: so i had to add them from the A pillars to the fakra connector at the radio (iirc)
HTH
07 350 170ps
Ids map here
loot
Postby Punto443 » Sat Sep 10, 2016 11:25 pm
Mine was missing the section between 57pin and the Apillars, but had the rest
Punto443
Postby loot » Sun Sep 11, 2016 10:10 am
That's the 1 i remember now, so you plug the stereo in then you plug the speakers in and you are left scratching yer head.
I think there's a few things that do that isn't there
loot
Postby Deb123 » Fri Apr 23, 2021 10:13 pm
This is brilliant thank you. Using your diagram I’ve found the place in the 57 pin that the speaker wires go. Apparently I need molex connectors though. Don’t suppose anyone knows which size or can tell me whether I need the male or female ones please?
Deb123
