MK 2/3/4/5) 2.5Di wont start when cold
Re: 2.5Di wont start when cold
Postby robbie.cee » Tue Feb 01, 2011 12:43 am
[quote="vinny55"]if all else fails replace battery leads and check earth leads you can put a earth to the body of starter mine still starts here in poland and it was -28c last night heater plug only comes on at -15c cold like this for 4 months + 2mtrs snow abs helps but still sh*t in snow[/quote]
ha like it.good use of english m8! you have heater plugs? very posh!!!! we dont have those on our blocks!
gonna try new leads myself as i have some spare very thick wires with terminals on from car stereo he he he
robbie.cee
Postby robbie.cee » Tue Feb 01, 2011 12:44 am
water in fuel filter???
robbie.cee
Postby ake » Tue Feb 01, 2011 7:26 am
No Transit Di ever had heater plugs, Some european ones do have a Flame Start plug, but that is quite differant to a glow plug
Postby woodsman » Fri Feb 04, 2011 9:49 pm
Only just found this forum! I have an ex bt 120, owned it for around 5 years.Last few winters whenever frost arrives I get the cold starting problem,luckily we live at the top of a hill. A few weeks ago I remembered there is a previously unused water heater under the van from the bt days.Googled operating instructions and set timer to come on half hour before starting.Not only does she start straight away now but also a lovely warm cab waiting for me!
woodsman
Re:
Postby stevefirestorm » Sun Mar 27, 2011 8:07 pm
[quote="Example Post"]My 2.5 Di wont start on cold mornings :!: it has been fine all summer but whenever its cold it wont start :(
do you think it will be the glowplugs :?:[/quote]
Buy a thermostart unit (cost about £20-30),wire it through a push button,and pipe fuel to it from a small container just above it to allow a gravity feed.Most inlet manifolds have a blanking plug you can remove and the"hotstart" unit will screw in.Once wired in all you need to do is press button for about 15-20 secs and it will fire up instantly.!!
stevefirestorm
Re: Re:
Postby ake » Sun Mar 27, 2011 8:16 pm
stevefirestorm wrote:
Example Post wrote:My 2.5 Di wont start on cold mornings :!: it has been fine all summer but whenever its cold it wont start :(
Completely unnecessary in the UK if your van is properly maintained
Postby keep um going » Fri Aug 19, 2011 11:50 pm
If your van is hard to start in winter what solved it for me was adding fuel system cleaner to the diesel in the tank. I've even added a gallon of parrafin per tankfull in the winter and never had a problem.
keep um going
Postby robbie.cee » Sat Aug 20, 2011 4:29 pm
[quote="woodsman"]Only just found this forum! I have an ex bt 120, owned it for around 5 years.Last few winters whenever frost arrives I get the cold starting problem,luckily we live at the top of a hill. A few weeks ago I remembered there is a previously unused water heater under the van from the bt days.Googled operating instructions and set timer to come on half hour before starting.Not only does she start straight away now but also a lovely warm cab waiting for me![/quote]
you lucky git! wish i had one in each van!!! enjoy it!!!
does it heat the engine water or also feed a small tap for handwash too??
rob
robbie.cee
Postby ake » Sat Aug 20, 2011 6:30 pm
robbie.cee wrote:
woodsman wrote:Only just found this forum! I have an ex bt 120, owned it for around 5 years.Last few winters whenever frost arrives I get the cold starting problem,luckily we live at the top of a hill. A few weeks ago I remembered there is a previously unused water heater under the van from the bt days.Googled operating instructions and set timer to come on half hour before starting.Not only does she start straight away now but also a lovely warm cab waiting for me!
rob
Originally it would have done both
Postby leslie webster » Fri Nov 11, 2011 5:18 pm
hi like your idea of thermostart where can i get one. peed off.! les. cheers.
leslie webster
Postby transitandy » Sun Nov 20, 2011 12:13 am
[quote="leslie webster"]hi like your idea of thermostart where can i get one. peed off.! les. cheers.[/quote]
welcome to the site m8y
Postby samson » Sun Nov 20, 2011 7:42 pm
[quote="transitandy"][quote="leslie webster"]hi like your idea of thermostart where can i get one. peed off.! les. cheers.[/quote]
welcome to the site m8y[/quote]
old di cold start whats the problem , never had one, my 98 di start as it should
samson
Postby ake » Sun Nov 20, 2011 8:57 pm
leslie webster wrote:hi like your idea of thermostart where can i get one. peed off.! les. cheers.
Completely unneccesary on a UK Transit, as long as it is properly maintained
Postby KING OF ENGLAND » Sun Nov 20, 2011 9:21 pm
I never have any trouble starting my mk5,service it just before
the cold weather starts and make sure my battery is good,
i haven't done any of the mods either,maybe im just lucky
KING OF ENGLAND
Postby jamiewilson » Mon Dec 12, 2011 12:06 am
I agree just service and maintain.
jamiewilson
