MK 2/3/4/5) 2.5Di wont start when cold
Re: 2.5Di wont start when cold
Postby MrMPuk » Thu May 06, 2010 10:09 pm
poppyabe wrote:advance diesel pump on cam vernier 1 or 2mm and jobs a good n i will start like new
If you need to do that then your pump is badly worn.
Postby poppyabe » Thu May 06, 2010 10:22 pm
aint they all lol
poppyabe
Postby Angel205 » Mon Oct 18, 2010 3:18 am
Just reading through this very long topic - But mainly posting on it so I remember to come back and read it properly.. lol
Angel205
Postby Vee4 » Mon Oct 18, 2010 8:01 pm
[quote="Angel205"]mainly posting on it so I remember to come back and read it properly[/quote]The 'bookmark' function is useful for doing that.
The BBCode is not working on this topic, by the way - that's why the formatting is odd and no 'sig'.
Vee4
Postby G40GES » Sat Oct 23, 2010 10:24 am
can i get a CSC sticker... when ive the time and headspace ill digest this thread and solve the bugger... any thoughts on using a space heater on the engine bay in the cold weather just to take the chill off... as seems to be the way, good as gold all summer but once the cold hits turn turn turn flat... seems to be once the temp outside even thinks about hitting minus numbers!
still the best bus ive ever had!!!!!!
G40GES
Postby MrMPuk » Sat Oct 23, 2010 10:51 am
That would work but ultimately you need to check the connections and service it using the correct 5w30 semi-synthetic oil.
Postby G40GES » Sat Oct 23, 2010 11:32 am
Can i ask, always 5 30 oil? i did the change and filter 500 miles ago and did think it span a little slower (ears and brain both pretty shot!)
but i was advised on 10 40! (bennets £32 for 20 ltrs)
G40GES
Postby MrMPuk » Sat Oct 23, 2010 11:33 am
10w40 what?
Postby G40GES » Sat Oct 23, 2010 11:34 am
MUST GET BUSY WITH THE GRINDER AND LUBE :)
G40GES
Postby G40GES » Sat Oct 23, 2010 11:35 am
[quote="MrMPuk"]10w40 what?[/quote]
semi ( is it me or does these random post comeoveras a little twisted :) lol
G40GES
Postby MrMPuk » Sat Oct 23, 2010 1:01 pm
10w40 should be mineral oil if used but you are better off with 5w30 semi-synthetic.
Postby G40GES » Sat Oct 23, 2010 1:33 pm
cheers MrP, and is this correct for any age engine or change viscos at a certain point? how often do u recommend oil dumping and renewal?
G40GES
Postby boggie40 » Thu Nov 11, 2010 10:49 pm
I had this exact problem the battery i had was - part no 069 CCA SAE 570amps AH(20h) 65amps which is what all the books say you should have.
I changed it to -part no 249 730 amps 90amps and i have not had a days trouble since.
Although i am already regretting i ever said that !!!!!
boggie40
Postby michael clohessy » Thu Nov 18, 2010 12:39 pm
I have a 2.5tdi and have had a problem starting in the cold mornings, i had the glowplugs replaced last year so new they were fine. It turns out that it was a relay that was playing up, if you open your main fuse box under the bonnet and look to the top you will see two big grey relays one to the left and one to the right, the one on the left is to work the heater plugs, try replacing that. Also my heater plug light was comming on when driving and i was loosing power, i havent had that problem since.
michael clohessy
Postby ake » Thu Nov 18, 2010 4:35 pm
michael clohessy wrote:I have a 2.5tdi and have had a problem starting in the cold mornings, i had the glowplugs replaced last year so new they were fine. It turns out that it was a relay that was playing up, if you open your main fuse box under the bonnet and look to the top you will see two big grey relays one to the left and one to the right, the one on the left is to work the heater plugs, try replacing that. Also my heater plug light was comming on when driving and i was loosing power, i havent had that problem since.
You dont get glowplugs on a 2.5 Di, you must have a 2.4 Duratorq, which is not relevant to this thread
