MK6 fuses, relays and earth points
Postby ned » Sun Feb 23, 2020 8:35 pm
Fuses, relays and earth points lifted from the Haynes book of lies, hope it helps :D
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Re: MK6 fuses, relays and earth points
Postby ned » Sun Feb 23, 2020 9:40 pm
Engine bay relays,
R1 = starter.
R2 = glow plug/cooling fan.
R3 = horn.
R4 = main beam.
R5 = generator cut-off.
R6 = dip beam.
R7 = engine management.
R8 =
R9 =
R10 =
R11 =
R12 = cooling fan high speed.
R13 = ignition.
Passenger side relays,
R14 = windscreen wiper.
R15 = battery saver.
R16 =
R17 =
R18 = interior light.
R19 = rear door warning buzzer.
R20 =
R21 = rear wiper.
R22 = heated rear window/mirror.
Auxiliary fuse box relays,
AR1 = trailer tow.
AR2 = RH direction indicator.
AR3 =
AR4 = LH direction indicator.
Diode,
D1 =
D2 =
D3 = trailer tow RH.
D4 = trailer tow LH.
ned
Postby bambi mk 1 » Sun Feb 23, 2020 9:54 pm
There are at least three different layouts depending on the year Ned :wink:
bambi mk 1
Postby Altransit » Sun Feb 23, 2020 11:21 pm
There are also two fuses taped into the loom underneath the steering column, which power the central locking.
Postby mini_mayhem » Sat Aug 22, 2020 9:43 am
Thanks, This is useful stuff!
mini_mayhem
