MK 6/7) turning off the service light?
Re: turning off the service light?
Postby hop2it » Tue Nov 08, 2011 11:20 pm
[quote="ake"]To switch off the service light in your MK6 or MK7 Transit:
1. Service it
2. Switch on ignition but don't start engine
3. Press Down Brake pedal and Throttle pedal fully, and hold till service light flashes this may take up to a minute, but usually about 15 seconds
4. Switch off igniton
Job Done
On a MK 7 the service light is a picture of a Spanner
On a MK 6 the service light is a picture of a Spanner and an oil can[/quote]
This worked perfectly for me and my mk6. Thanks for your help
hop2it
Postby martynx » Fri Nov 25, 2011 5:50 pm
Wait 2 mins before turning ign back on. That's a good tip! Never knew that.
martynx
Postby luapnedloh » Thu Dec 08, 2011 11:25 am
Hi, new to the site so go easy on me please fellas.
Just bought a secondhand mk7 and Ive done the reset thing with the brake and accelerator pedals.....but i still keep getting the SERVICE OIL NOW message everytime i
start the engine.
Any ideas?
luapnedloh
Postby ake » Thu Dec 08, 2011 7:08 pm
If it is a 140Ps or 200ps they have oil quality sensors, it may well need an oil service
2 x 18 Custom 270 Trend
2 x 67 Custom 270 Trend
3 x 66 Custom 270 Trend
1 x 65 Custom 290 Limited
7 x 12 Transit 260 Trend
Or is it something worse?
Postby luapnedloh » Thu Dec 08, 2011 11:26 pm
its a 110 .....ive reset it several times and it still comes back on every time i start the engine?
luapnedloh
Postby ake » Fri Dec 09, 2011 7:25 am
Have you waited the required 2 minutes after reseting it before starting the engine :?:
Postby luapnedloh » Fri Dec 09, 2011 4:32 pm
yep, left it for 2 minutes and then some before restarting.....still persists in coming on with every turn of the ignition key
luapnedloh
Postby taz666 » Sat Dec 10, 2011 6:30 pm
luapnedloh wrote:yep, left it for 2 minutes and then some before restarting.....still persists in coming on with every turn of the ignition key
do you get the complete message come up?
taz666
Ford Technician
Postby luapnedloh » Sat Dec 10, 2011 6:54 pm
what is the complete message?
luapnedloh
Postby taz666 » Sat Dec 10, 2011 7:18 pm
the complete message comes up when the oil reset is complete, read my complete post earlier on in this thread on how to reset and this will explain
taz666
Ford Technician
Postby luapnedloh » Sat Dec 10, 2011 11:42 pm
Oh right yeah. i get the message that the reset is complete yes.
Is the only reason this warning comes on to signal that its time for a service?...or are there other reasons i should be worried about?
luapnedloh
Postby taz666 » Sun Dec 11, 2011 9:38 pm
luapnedloh wrote:Oh right yeah. i get the message that the reset is complete yes.
no thats basically it, the pcm goes on drive cycles and milage to work out when the oil needs replacing, on the 140 and 200 ps it also has a oil sensor which measures oil polution
taz666
Ford Technician
Postby luapnedloh » Mon Dec 12, 2011 2:51 pm
Okay,cheers for that info taz.
The van cam with full service history and the last service it had was in June this year so im assuming the oil was changed then.
Do i need to take the van in and get someone to switch the warning light off by some other means?
luapnedloh
Postby pondskater » Sun Feb 05, 2012 1:59 pm
Just gone through sequence for extinguishing the service light , brill its been driving me to distraction ever since i changed the oil a couple of weeks ago
Cheers
pondskater
Postby motorman116 » Thu Mar 08, 2012 9:39 pm
The service light on my van came on tonight, followed the instructions on here, and it worked a treat...
Thank you
motorman116
