MK 7) Fuse Details Fuse Box Location
Re: MK 7) Fuse Details Fuse Box Location
Postby fastwestie » Thu Jan 12, 2017 7:03 pm
Hi
I'm looking for the trailer tow module fuse (83) which is supposed to be in the passenger foot well. Just spent 1 hour looking there but could not find it.
Anyone have any idea?
fastwestie
Postby fastwestie » Fri Feb 17, 2017 6:32 pm
To answer my own question, the fuse is with the trailer tow module at the rear of the passenger step under the plastic cover
fastwestie
Mk7 Battery Fuse Box
Postby v8dave » Wed Dec 27, 2017 1:30 pm
Mk 7 battery or pre-fuse box.
Details from the ford owners handbook.
It lives in the rear of the drivers seat support behind the battery.
Note: this is the dual battery version with the large battery isolator relay. Single battery versions have a solid link in it's place. Access requires you to remove the battery restraint frame.
mk7 08reg 2.4 T350 LWB MHR RWD
mk6 X reg 2.4 T350 LWB MHR RWD - scrapped
mk4 J reg 2.5 L300 LWB MHR RWD - sold on
Notice a trend there ? not too big and not too small
v8dave
Postby 2e1bts » Thu Aug 09, 2018 4:36 pm
Hi all,
Thanks firstly for great info, would never i a million years located the sneaky fusebox.
Problem i currently have is twofold, firstly radio stopped working. i did fit new after market one, have fitted original back also now not working
checked voltages on red and yellow, have ignition power 12.1v but no perm 12v.
removed new adapter loom and confirmed same on the master loom plug.
Used your info regarding fuses checked both have continuity not just visual check.
2nd part of the puzzle is the reversing sensors now don't work, coincidence i don't think so not been able to locate the control box as yet. i have a mountain of extra relays fuses and boxes in the van (ex gas board / transo one) so have the genny and compressor aux lights heater and all the other gubbins that goes on in the back. this all works at moment so don't think related in anyway.
A look on line seems to show other people having a similar fault to this but no answers given. i have spent the last three night for couple hours each and got no where as yet. totally confused and perplexed as to why this is going on !!!
any ideas gratefully received
Adrian
2e1bts
