MK 7) hunting/surging at idle, lacking power, p0089
Re: mk7 hunting/surging at idle, lacking power, p0089
Postby jacko1611 » Sat Jan 15, 2011 2:47 pm
have u fit a new one then?
jacko1611
Ford Technician
Postby SAFtransit » Sat Jan 15, 2011 5:15 pm
No not yet,I just took the old one out to see if it was faulty.Then put it back in and the van is running fine now?
Mabe will just come apart again over time through?
cheers.
SAFtransit
Postby fedup2 » Sat May 07, 2011 11:25 pm
jacko1611 wrote:have u fit a new one then?
Why would he need to? What is it that changes on the valve to need renewing?
fedup2
Postby jacko1611 » Sun May 08, 2011 11:07 am
if it comes out in pieces, spring plunger etc. then its blown and needs a new one.
should just be in one piece and screw into rail.
jacko1611
Ford Technician
Postby jpgroup » Sat Dec 10, 2011 6:02 pm
ive had the exact same problem,
ticking over eraticaly at standstill , just put on a new FUEL VAPOUR valve on the pump and had the pcm and fuel pump learn carried out at wigan last saturday now its back to it same old game , when your in the drivers seat it feels like its a 6 cylinder ticking over !!!
if any of you can help it will be apppreciated
cheers
jpgroup
Re: MK 7) hunting/surging at idle, lacking power, p0089
Postby andygb » Tue Mar 05, 2013 1:14 pm
Picked up my van last week 2.4 140 and its started to surge on and off and now its just cutting out not good only had it a week ?
andygb
Postby jonny24 » Mon Apr 01, 2013 3:01 pm
I know I must sound really stupid just checked what was wrote on the first page checked the prv an fuel does not leak out of the rail it comes out the black pipe is that ok or does it need replacing lol
jonny24
Postby fedup2 » Mon Apr 01, 2013 3:37 pm
[quote="jonny24"]I know I must sound really stupid just checked what was wrote on the first page checked the prv an fuel does not leak out of the rail it comes out the black pipe is that ok or does it need replacing lol[/quote]
you need to unscrew it to be sure.If it comes out in bits its knackered.Even if it comes out in bits you can put it back in if you havnt got a new at hand.
fedup2
Postby jonnyb657 » Sun Aug 11, 2013 11:04 pm
Been worrying why my van was idling so strange great help
jonnyb657
Postby french1292 » Fri Oct 18, 2013 8:22 pm
Am I right in thinking To do a fuel pump learn do you disconnect the battery for 10 mins then reconnect and leave the van Idealing for 10 mins? And what is a pressure valve reset? Can any1 help please????
french1292
Postby ake » Sun Oct 20, 2013 6:23 pm
french1292 wrote:Am I right in thinking To do a fuel pump learn do you disconnect the battery for 10 mins then reconnect and leave the van Idealing for 10 mins? And what is a pressure valve reset? Can any1 help please????
No, it needs to be recalibrated using Ford ids, the count reset is part of the process
2 x 18 Custom 270 Trend
2 x 67 Custom 270 Trend
3 x 66 Custom 270 Trend
1 x 65 Custom 290 Limited
7 x 12 Transit 260 Trend
Or is it something worse?
Postby ricmuns » Wed Nov 27, 2013 4:18 pm
sorry, i'm really new at this. where would i find the pressure relief valve to check it?
cheer guys
ricmuns
Postby ricmuns » Wed Nov 27, 2013 4:58 pm
just spoke to ford about getting booked in for the pcm recalibration and i have been told that they have to do a full check of the system at a cost of £90.
just thought i'd share.
ricmuns
Postby Sharpy30 » Fri Jun 13, 2014 4:00 pm
Hi after reading this post my van has something similar was wondering if any1 knows wht to do next after buying it 2 weeks ago it's had new injector seals 'fuel tank emptied and cleaned new filter it's had new turbo pressure relief valve and PCM update this cured rough idle and van drove ok for 2 days then it wouldn't start but only when engine hot so I put a bigger battery in the next day engine management light came on and later the cog?powertrain? Light came on and it's now in limp mode . I can't afford to put it bk in2 ford ,any ideas ? It's a 56 plate 2.2 fwd 85/280 thanks
Sharpy30
Postby karl » Fri Jun 13, 2014 6:51 pm
I would suggest another code read and go from their
If the light is on its got codes stored either dodgy injector or egr knackered
karl
Tranny Lover!!!
