MK 6) Leaking Roof
Re: Leaking Roof MK6
Postby TIMO » Thu May 10, 2012 10:18 am
That will do it but i would rather use tigerseal.
We use tigerseal on the boats ,, superb gear .
TIMO
Re: MK 6) Leaking Roof
Postby Doglady » Mon Jul 22, 2013 6:42 pm
I have had roof leeks with both TC vans, mine was from the grommets where the roof racks would be fitted. Sealed them both wit waterproof tape, it works well.
Doglady
Postby mickyacky » Mon Dec 09, 2013 12:16 am
I had a 2.0l swb low van that done the same thing, i used k11 it out lived the van.
mickyacky
Postby mickyacky » Sun Dec 15, 2013 10:59 pm
All the above will work it depends on your prep work i.e rubbing down, cleaning grease etc for adhesive to bond. Torch on roof felt strip would last lol depends on the condition of the van as to the repair you want
mickyacky
Postby telgsx » Tue Sep 23, 2014 8:11 pm
How is the best way to repair holes in the roof just off the seam?
telgsx
