MK 6/7) Single or Dual Mass Flywheel
Re: MK 6/7) Single or Dual Mass Flywheel
Postby JoelHatton » Mon Oct 21, 2013 12:12 am
So when i had my flywheel done earlier this year i made the right decision sticking with a DMF?
JoelHatton
Postby ake » Mon Oct 21, 2013 7:24 am
JoelHatton wrote:So when i had my flywheel done earlier this year i made the right decision sticking with a DMF?
I would have said so, however opinion, as always, is divided
2 x 18 Custom 270 Trend
2 x 67 Custom 270 Trend
3 x 66 Custom 270 Trend
1 x 65 Custom 290 Limited
7 x 12 Transit 260 Trend
Or is it something worse?
Postby Jamysumm » Mon Oct 21, 2013 10:35 am
[quote="ake"][quote="JoelHatton"]what are the benefits of changing to a smf?[/quote]
Increased vibration, potential damage to gearbox input bearing, but hey you might save £50[/quote]
Id like to point out that I replaced the dmf with a smf as that's what should of actually been in it to begin with , and as far as I know there is no benefit to putting a dmf in an 85ps transit anything over100ps then yes but thats how they come from the factory anyway soo
Jamysumm
Postby Kaymar » Sun Apr 09, 2017 2:19 pm
I have a SMF fitted as a replacement flywheel during a gearbox replacement; was told being simpler was more reliable. The DMF that came out was almost in two parts. I don't think it is quite as smooth as old one. Only issue so far (40,000kms) is a replacement starter motor sometimes whirrs against the flywheel instead of engaging (engages 90% of time). Was told of a critical distance between the pinion and face of flywheel that may be being compromised by different flywheel. Strange!!
Kim
Kaymar
