hill start
hill start
Postby loot » Sun Oct 26, 2014 6:26 pm
Evening all, i have new speedo with hill start assist, i have abs and esp, I'm wondering what else i need to activate hsa? Do i need a tilt sensor? I see in config there is' tilt sensor if cat 1 alarm' it then occurred to me, would that be needed for hsa too?
How does hsa work?
Ids map here
loot
Re: hill start
Postby v8dave » Sun Oct 26, 2014 6:45 pm
hsa keeps the brakes on for a couple of seconds when it senses that your on a steep enough hill.
It does depend on what your doing with the brake and clutch as to whether it activates.
I assume it uses the abs valves to keep the brakes on.
Do you have the yaw rate sensor for stability assist, it is fitted to the left of the bcm on the front bulkhead. It has a four pin connector.
Edit:
You can turn the system on or off by turning on the ignition and holding all three pedals down for 8 seconds, the dash indicator flashes to confirm the change. Don't hold the pedals too long or the service counter resets
mk7 08reg 2.4 T350 LWB MHR RWD
mk6 X reg 2.4 T350 LWB MHR RWD - scrapped
mk4 J reg 2.5 L300 LWB MHR RWD - sold on
Notice a trend there ? not too big and not too small
v8dave
Re: hill start
Postby loot » Sun Oct 26, 2014 6:56 pm
I have yaw sensor, for some reason i thought it was just a horizontal gyro but if it is full giro then that makes sense :-)
Will i have hill assist in config? :-)
Ids map here
loot
Re: hill start
Postby v8dave » Sun Oct 26, 2014 7:07 pm
If you have the yaw sensor then you've got stability assist so it is probably just a config option to get hsa as well.
If you had traction control then you would not have the yaw sensor or the steering angle sensor.
v8dave
Re: hill start
Postby Dash » Mon Oct 27, 2014 11:19 pm
I'm sure there's option in ids under body/braking to turn this on and off loot
Dash
Re: hill start
Postby loot » Mon Oct 27, 2014 11:21 pm
Dash wrote:I'm sure there's option in ids under body/braking to turn this on and off loot
Sweet I'll have a look :-)
Doesn't matter how much you use ids there's always treats hiding in there for you :lol:
Ids map here
loot
Re: hill start
Postby loot » Mon Jan 12, 2015 7:26 pm
Well i installed the software which i thought would activate hsa but i couldn't see it in config, didn't check to hard tho tbh as i was in config for another reason, on the way home i thought if stop on a hill but before that i stopped by the side of the road and tried the 3 pedal trick but nothing happened twice so i swore and went home :-(
I can't find anything in the wiring diagrams for a tilt sensor so I'm happy that it uses the yaw sensor or something.
The hunt continues :-(
Ids map here
loot
Re: hill start
Postby paul2012 » Mon Jan 12, 2015 7:44 pm
loot34 wrote:Well i installed the software which i thought would activate hsa but i couldn't see it in config, didn't check to hard tho tbh as i was in config for another reason, on the way home i thought if stop on a hill but before that i stopped by the side of the road and tried the 3 pedal trick but nothing happened twice so i swore and went home :-(
Is it listed under the menu's on instrument cluster :?:
When I fitted ABS/ESP with HSA (Hill start assist) on my Last Transit Connect project. You could turn it on or off via vehicle settings menu on instrument cluster.
Although it was nowhere to be found on IDS. Apart from having to configure all sensors before it would work.
All that was require on connects was instrument cluster, ABS/ESP pump & Yaw/Rate sensor.
Could it be the same for Transit Mk7 :?:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Re: hill start
Postby loot » Mon Jan 12, 2015 8:15 pm
I only remember seeing calibrate steering senator but I'll have a look tomorrow, i don't think there is a menu item I'm sure I've been through them all.
Recently looked at some stuff you could activate in focus/possibly the connect using a modified elm327, flat tyre warning for eg which is based on a flat tyre affecting the rolling radius on the abs sensor, think we need valve sensors etc on ours :(
Anyway, I'll have a look tomorrow, thanks Paul
Ids map here
loot
Re: hill start
Postby kobe » Tue Jan 13, 2015 12:30 am
loot34 wrote:Evening all, i have new speedo with hill start assist, i have abs and esp, I'm wondering what else i need to activate hsa? Do i need a tilt sensor? I see in config there is' tilt sensor if cat 1 alarm' it then occurred to me, would that be needed for hsa too?
How does hsa work?
hi loot.
I have hill start fitted to my newly acquired mk7 115, if as mentioned in my thread last week ( viewtopic.php?f=5&t=154058 ) I get over to you for a general prv/scv IDS tune up your welcome to have a poke around how it works.
cheers
kobe
Re: hill start
Postby loot » Tue Jan 13, 2015 8:40 am
Will do cheers :-)
Ids map here
loot
Re: hill start
Postby ake » Tue Jan 13, 2015 6:37 pm
There's no menu like that on the Transit MK7 :(
Re: hill start
Postby loot » Tue Jan 13, 2015 6:41 pm
Paul's the man :-)
That was the only good news tho :-(
Went into it and it came up test failed :-(
I have no clues as to what i need etc.
Nothing in wiring diagrams.
I haven't installed any calibration data for it but nothing shows up relating to hsa that I've ever seen in config.
I have abs/esp/steering angle sensor/yaw sensor fitted.
Can i find out if i need a higher spec abs pump?
I'm going to install software from a van that i know has hsa and see what happens.
Apart from that I'll check the fuses and relays to see if any are for hsa?
Anyone got any ideas?
Thanks.
Ids map here
loot
Re: hill start
Postby mjsroofing » Tue Jan 13, 2015 11:00 pm
Hill assist also turns off when it detects the engine under strain , so you trying to pull off.
Not sure how it detects this, but you'll need it.
Just so you know too,
Foot on clutch and brake while in gear will activate hiss asist, as long as your on a slop. It dint have to be a big hill.
www.mjsroofing.co.uk
2022 2.0 ecoblue fwd, 72k
2009 2.2 tdci 115ps just over 110k now.
2002 2.0 tddi 100ps. Over 205k still sweet . Now owned by Jay.
2001 escort van 75, 1.8 turbo intercooler. scrapyard heaven
1995 escort van 50, 1.8 straight diesel, scrapyard heaven.
mjsroofing
Re: hill start
Postby loot » Tue Jan 13, 2015 11:20 pm
OK so in your normal driving conditions do you see the little lamp on the clocks when you go to junctions etc? Only time I've ever seen mine is when i pot the key in the ignition, I've never sewn it or felt it in the time I've had these clocks fitted :-(
I did the 3 pedals and ignition to activate it but the lamp didn't flash, and today i got a fail to activate it in ids, I'm running out of ideas lol
Ids map here
loot
