fitted new tensioner, peice of cake!.
1. take off top fan cowl, three torx screws hold it on.watch out for wiring that runs across top
2. insert 3/8" drive breaker bar into square hole on tensioner, make sure this is firmly in place. keep pushing in with free hand if necessary. tensioner is made out of very soft alloy and bar will twist out if not carefull.
3. rotate tensioner anti clockwise to release drive belt.
4. undo central bolt on tensioner and remove, tensioner will now pull away from front of engine.
refit in reverse order. 30 mins max
