oh no.....
oh no.....
Postby thunderider » Fri Mar 09, 2007 5:52 pm
i whent to check the water in the header tank,opened the top looked in and i found what i thought was oil in the water,so i took it back to the people who built the engine,so he looked dipped his finger in,tasted it sniffed it and assured me it wasnt a blown gasket and it wasnt oil,cus i wasnt over heating or loosing an unfeaseable amount of water,it uses the amount between the top level mark and the sticky out ridge about every 4-5 thousand miles,so any thoughts on this brown murky sludge could it be residue from the rad?bearing in mind the rad probly hasnt been flushed in 302,000 miles,the vans running constantly for about 10-18 hours a day on motorway????
I am the god of hell fire.....
thunderider
Postby madmark » Fri Mar 09, 2007 7:06 pm
:shock: 302k wow you could have 1 of the only mk6 vans too do that sort of miles! :wink:
Postby Nighthawk » Fri Mar 09, 2007 11:29 pm
has the sludge suddenly appeared?
If so, it would suggest an oil cooler failure as being the prime suspect.
If it's been there a while it might be down to the coolant system not being cleaned correctly.
Aerial liquid works well to remove oil contamination from within the cooling system :)
Transit.........Job done
Nighthawk
Postby edy » Sat Mar 10, 2007 1:12 am
mine has done 270151 at last count, (im going of the sheet) its done more by now, i dont check it
edy
Postby thunderider » Sat Mar 10, 2007 8:15 pm
yes it apears to have happend suddenly,if it is the oil cooler is this problematic,short term or long term? would it be an easy fix?
ariel liquid?do just pour it in to the header tank??
thunderider
