mk6 transit "starting problem"
Postby jamiemk6 » Tue May 19, 2015 7:55 pm
Hi all! have been searching the site and havent been able to find anything definitive so thought id add to the rest ;)
My 85ps mk6 swb fwd transit is having starting problems from cold or when the van is left for a period of time (half hour plus)
Once started it runs like a champ with no smoking, chugging or missing it just takes a few attempts to start sometimes and under prolonged cranking will store p1563 and p1664 which i understand are related to the injection pump control module, if i crank for a few revolutions and then turn key off and try again it will catch and when i keep cranking will start and idle lovely.
Through research on this wonderful site i have narrowed it down to a few possible culprits.
Timing chain tensioner: not ruling it out but i definitely DO NOT have any cam chain rattles any time it starts (when i changed the oil for specified 5w30 it rattled its head off untill it had pressure at the tensioner (2-3 secs) so im aware of what this particular engine sounds like with a loose chain)
Air ingress: I have changed the fuel filter for a fram item (my father works at a motorfactors and got all the service parts at a good price) which i primed with valvoline system cleaner and it started first revolution after this, although i have read the ford ones seem more reliable. To be honest im a motorcycle techy so have not spent much time around diesel engines :S and would like some pointers on where to look for air ingress/how to test.
What i have noticed is a little "misting" around injector 4 (furthest from chain) no pooling but maybe air is getting in around here?
Any help would be greatly appreciated as it drives really nice for having 122,000 miles on it :) just dont want to lunch a starter motor.
Thanks in advance jamie.
jamiemk6
Re: mk6 transit "starting problem"
Postby jamiemk6 » Thu May 21, 2015 10:25 pm
Start with the simple things, iv put a genuine fuel filter on so will report tomorrow of its better :D
jamiemk6
Postby paul2012 » Thu May 21, 2015 11:01 pm
Have a look here :arrow: viewtopic.php?f=31&t=154710 :wink:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby jamiemk6 » Fri May 22, 2015 10:21 am
Thanks Paul there's some quality toilet reading there :lol: changed filter last night primed with fresh fuel and no change. Filter head next I reckon.
jamiemk6
Postby jamiemk6 » Fri May 22, 2015 12:19 pm
just a note when I removed the filter last night it wasn't full to the brim...should it be?
jamiemk6
