Yes the battery is under the seat, check it for voltage, see if you can get a jump off jump leads to see if the extra power will start it up, if so then try putting the battery on charge, if that doesn't work then you'll have to replace the battery.
56 350 2.2 130ps mk7 with 2 side doors
65 290 2.2 125ps custom with 2 side doors
07 350 170ps
Ids v86 licence + v86.04 update + xprog
hereIds map
here
