You can blank it but the warning lamp will come on, you need it deleted from the pcm for it to stay off, a reputable tuner can do it such as vantuner
You can also fit the blanking plate that has a hole in, the idea is that it allows enough return pressure to keep the maf happy, whilst minimising the oil crud that goes into the inlet. Ppl get varying results with this.
There's differing views on removing the egr, i would say it is best suited to non vnt engines ie. Upto 125 pre euro 5. But that's my opinion.
Stick a blanking plate in and see how you feel about it, the lamp will come on but that's all it is for now, it won't affect it ie. Limp mode iirc.
You can make it a permanent solution when you've decided how your van feels.
Remember tho that blanking it means that the turbo is forced to supply all the boost.
56 350 2.2 130ps mk7 with 2 side doors
65 290 2.2 125ps custom with 2 side doors
07 350 170ps
Ids v86 licence + v86.04 update + xprog
hereIds map
here
