Thanks in advance
satanslittlehelper wrote:Hi, Thanks for the reply, just noticed on another thread that there was a 120? If that's correct would that be ok to fit? thanks again. like the front end conversion by the way!
satanslittlehelper wrote:Ideally I'd like to have the 135 back together but I think he said the cam carrier is broken, so maybe chain slip? This seemed to happen at 5 years old and 80 k as it's been sitting in bits since then. I'm worried that if I get another head, (or engine) there may be problems or damage to the other components (injectors ect)The 120 is a complete running van (but rusty) and I thought once the conversion was done it could be a reasonably reliable van, as you say the 135 isn't easy to come by, especially as I live in west Cornwall!
Am I just better off lookin for an engine for it? Also there is the budget to consider, as the more I spend on the van the less I have for the camper conversion! Has anyone on here done the tdci to tdci swap and found that maybe it's just not worth it? All you advice is greatly appreciated!
andypdq wrote:satanslittlehelper wrote:Ideally I'd like to have the 135 back together but I think he said the cam carrier is broken, so maybe chain slip? This seemed to happen at 5 years old and 80 k as it's been sitting in bits since then. I'm worried that if I get another head, (or engine) there may be problems or damage to the other components (injectors ect)The 120 is a complete running van (but rusty) and I thought once the conversion was done it could be a reasonably reliable van, as you say the 135 isn't easy to come by, especially as I live in west Cornwall!
If you like the idea of simplicity, another option is to consider fitting the TDDI with a mechanical fuel pump. Guaranteed instant success with no electronics hassle.
