MrMPuk wrote:ass?
mickanic wrote:I have connected the pipe and want to bleed the clutch - do you just bleed it through with a pipe and bottle? or a pressure bleeder
mickanic wrote:there is a bleed screw - think i will pressure bleed it - thanks for your input tonight - coco time cheers mick
transitgeoff wrote:dont remove the clip fully pull it out a bit and the pipe can be moved back, this opens the way for air to be bled, get someone on the pedal and bleed away
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot]
