Focus C max steering wheel swap, which airbag do I need?
Postby robadob » Fri Mar 15, 2019 12:32 pm
Decided my 2010 T300 115 steering wheel was getting really tired, to the point it would make your hands dirty everytime you drove the van so did a bit of research and found the Ford Focus C max has a nice leather wheel with alloy inserts so decided to fit that.
On it went and plugged in the airbag, buttoned it all up, tested it and the airbag light comes on with the ignition, goes out for 10 seconds or so, then pops back on again and stays on until you switch off.
I have tried another bag, 2005-2010 focus airbag but does the same thing.
Do I need the airbag light reset due to me swapping things about or is there a conflict regarding the C max/Focus airbag and the Transit?
Or do I need a specific airbag to sort this?
part number for the fitted airbag is 4M51 A042B85 CF 3ZHE
Thanks in advance.
robadob
Re: Focus C max steering wheel swap, which airbag do I need?
Postby blue estate » Fri Mar 15, 2019 1:05 pm
Put your transit airbag back on , it fits the Cmax wheel :wink:
Y reg Honda accord 2ltr Auto
My other car is a 44t MAN TGX 480 tractor unit
blue estate
Postby robadob » Fri Mar 15, 2019 4:44 pm
Ooooooo does it???
The back does look different though but.......Ill give it a go!
robadob
Postby andz327 » Fri Mar 15, 2019 6:39 pm
If you put ignition on with any
sh!t unplugged then you'll need sh!t reset robadobber
ANDZ
If its this style yer bag will fit it
andz327
Postby twin--turbo » Fri Mar 15, 2019 7:44 pm
My airbag light stayed on for a couple of ignition cycles I recall.
TT
twin--turbo
Postby Jim Archer » Sat Mar 16, 2019 8:50 am
You'll probably find you have 2 DTCs, a lost power/connection to airbag and the steering angle sender needs calibrating.
Jim
Mk7 140 Jumbo - Vantunered.
Jim Archer
Postby Cider Andy » Sat Mar 16, 2019 9:08 am
I used the original airbag as the C-Max airbag had two connectors (for twin airbags, I believe). I did modify the wiring inside the steering wheel as the C-Max had some kind of suppressor on the brown ground wire and there was some other minor difference that I can't remember now, so I substituted the original ground wire and got not error codes/indicators.
I expect to have to recalibrate the steering angle sensor but I've yet to drive it because other things are in bits....
Cider Andy
Postby robadob » Mon Mar 18, 2019 2:17 pm
So, a bit of Transit witchcraft happened this morning.
Decided to try and fit the original airbag removed from the mk7 Transit wheel and....doesnt fit. The mountings for the airbag are completely different so I disconnected the battery, went for a coffee and then fitted my other spare Focus airbag......Light now comes on with the ignition and then goes out and stays out. Weird.
I didnt do anything different this time, Ive tried this airbag on another occasion and I still ended up with the airbag light on so a very odd one.
Not that I care now as I have a nice, leather wheel, horn works as it should and no airbag light, Yay!
Thanks for all the advice.
robadob
Postby Cider Andy » Tue Mar 19, 2019 9:14 am
robadob wrote:Decided to try and fit the original airbag removed from the mk7 Transit wheel and....doesnt fit. The mountings for the airbag are completely different...
It sounds like you've fitted a steering wheel from a newer C-Max: the c.2004 version looks identical to the Transit one (except the boss angle is slightly different so the steering angle sensor needs recalibrating).
But all's well that ends well!
Cider Andy
Users browsing this forum: Google [Bot], loot
