2005 mk6 2.4 tddi rwd singel wheel
Postby KING OF ENGLAND » Mon Apr 15, 2019 7:48 pm
Need some advice lads
have just bought the above van and it failed the mot on a few things (have done most of the jobs)
but the one fail was n/s/r wheel bearing has excessive play and I cant find any play so am I checking it wrong
now as many of you know im quite good on the tools
the only movement I can find is when you have it on stands you can pull the wheel outwards slightly but its the same the other side
is that normal
so how do I check play in the rear bearings and if it has gone il send it in to be done
regards craig
KING OF ENGLAND
Re: 2005 mk6 2.4 tddi rwd singel wheel
Postby knobby1 » Tue Apr 16, 2019 12:54 am
I think that's what he's on aboot....the lateral play. There's some shims in the diff which need changing I believe.
No. 22 in this pic:
http://www.catcar.info/ford/?lang=en&l= ... MjU2KzA%3D
Postby dumper » Tue Apr 16, 2019 9:14 am
Wasn’t there a recall on rear hub end float on the mk6
Postby KING OF ENGLAND » Tue Apr 16, 2019 8:42 pm
It appears having spoken to a ford mechanic
That the bearings very rarely go and it’s end float that they believe is a bearing problem
And should be an advise only
So just checked all old mots and it’s failed on rear bearings quite a few times and just found a receipt for new bearings last mot only one tester has advised end float
So I’ll sort the end float out and take it for retest
KING OF ENGLAND
Postby eugenemccabe101 » Fri Apr 19, 2019 2:18 pm
Hi Guys, I'm just about to do the rear hub oil seals on a 2005 RWD single wheel minibus, does this have an end float. The diagram looks like it's a twin wheel.
Sent from my HUAWEI VNS-L31 using Tapatalk
eugenemccabe101
Users browsing this forum: KIPPERMAN72
