2.4 RWD, non starter, flashing coil light.
Postby fitzy » Fri Feb 14, 2020 4:56 pm
Hi Guys
I replaced my alternator on Wednesday and fitted new battery, didn’t connect main cable to alternator as the original eyelet connector snapped off on old alternator, but she started and ran ok. Today I fitted new eyelet connector and connected to alternator, moved van to a new spot closer to my home, as she was ticking over, there was a slight splutter/cough and she cut out, now she won’t start, just turns over, coil light is flashing now as well. Could something have happened whilst she was running without the alternator connected? This is the first time I’ve started her over a year.
2002, 52 Reg, 125-T350, LWB, Semi High Roof, Metalic Pepper Red.
Electric windows, Electric heated mirrors, Cental locking & Air Con. In the process of retro fitting Heated Screen & Fog Lights.
fitzy
Re: 2.4 RWD, non starter, flashing coil light.
Postby knobby1 » Fri Feb 14, 2020 9:56 pm
If your coil light is flashing, it means you have fault codes stored, best get them read as guessing can become expensive and time consuming.
Running the engine without the alternator connected is not a great idea, it is capable of pumping out a huge amount of voltage/current.
Postby fitzy » Sat Feb 15, 2020 5:11 pm
Will my OEM JLR VCM work with the Ford IDS software?
fitzy
Postby knobby1 » Sat Feb 15, 2020 10:32 pm
fitzy wrote:Will my OEM JLR VCM work with the Ford IDS software?
Probably not. Just get yourself an ELM-327, they're cheap...and download Forscan, it's free.
Postby fitzy » Sun Feb 16, 2020 4:00 pm
I bought the elm327 with switch and installed forscan (Windows 7 32bit), but the drivers failed to load when I plugged in the elm327 and forscan won’t connect to van. I’ve installed what I think is the right driver from the disc, but still no joy. :oops: :oops: :oops:
fitzy
Postby fitzy » Sun Feb 16, 2020 5:32 pm
These are the fault codes i got, once i got Forscan working, i cleared thema and rechecked and onlu got P1665 x 2 and P0216. Are these fatal or fixable, one of them P0404 is the EGr valve?
fitzy
Postby knobby1 » Sun Feb 16, 2020 9:03 pm
fitzy wrote:These are the fault codes i got, once i got Forscan working, i cleared thema and rechecked and onlu got P1665 x 2 and P0216. Are these fatal or fixable, one of them P0404 is the EGr valve?
P1665 is fuel pump related, possibly the pump/timing solenoid playing up...P1608 suggests the wiring isn't happy, best to check the wiring to/from the pump/PCM first as it can sometimes be at fault.
EGR is just bolted on and can be repaired/replaced fairly easily.
I'd be checking all your engine looms for breaks/poorly connections etc..
Postby fitzy » Mon Feb 17, 2020 3:03 pm
Thanks Lord Knobrot
Should I concentrate on the list of faults that first appeared or just the 3 codes that arose after I cleared the initial list of codes?
fitzy
Postby knobby1 » Mon Feb 17, 2020 8:20 pm
fitzy wrote:Thanks Lord Knobrot
The P1665 code is the one you need to sort. The P0216 (CPS) I believe is a cranks sensor fault. Essentially they point to a communication or "possible" wiring fault.
Postby fitzy » Mon Feb 17, 2020 9:16 pm
I’m trying to look up fuel pump prices, but not sure which one I need. My van is a 125 T350. I can only find pumps related to the 120’s. Any ideas please?
fitzy
Postby Jim Archer » Mon Feb 17, 2020 11:50 pm
Those codes suggest it's more likely a wiring issue rather than the pump itself. Check the loom where the pump flying lead joins to the main engine loom to PCM/ECU.
Failing pumps usually give 2 pump codes - timing fault, plus pump/EDC communication fault.
Jim
Mk7 140 Jumbo - Vantunered.
271, 000 and counting.
Jim Archer
Postby inasinman » Tue Feb 18, 2020 1:48 am
Do what Jim says first.
If you’re gonna need a pump it’ll be either:
0470504040 or 0470504041 for the 125 ps.
Cheers,
MK6 125/350 LWB 2.4 RWD
inasinman
Postby fitzy » Tue Feb 18, 2020 2:37 pm
Are there any particular fuses I should be checking as well, checked fuse box under bonnet and all ok, forgot about the one behind glovebox? Is the wiring easier to check from above or below? Can the wiring just fail like this, never ever even spluttered in 8 years of ownership, was running sweet until it cut out after I changed the alternator, even though I did drive it around the block with out connecting the main cable to the alternator, was awaiting new eye connectors to arrive.
fitzy
Postby fitzy » Tue Feb 18, 2020 2:48 pm
inasinman wrote:Do what Jim says first.
Cheers,
Are these the Bosch VP30 or VP44 Pumps?
fitzy
Postby knobby1 » Tue Feb 18, 2020 8:19 pm
Cheers,
If it's a 125ps, it will be a VP-44. I believe only the 75 & 90 have the VP-30.
croncroncron
