Mk6 transmission oil replacement query
Postby Lazam1985 » Thu Apr 15, 2021 1:30 pm
Hi I have a Mk6 Ford transit
It has about 125k miles on the clock
Recently 2nd gear started to pop out every now and then and also has some grinding noises
If I bleed and change the transmission oil will this make any difference to this issue?
Or is it more likely a worn out synchro
will changing the transmission oil help ?
Also a rough estimates on how much a worn 2nd gear synchro is to replace?
Any help appreciated
Loz
Lazam1985
Re: Mk6 transmission oil replacement query
Postby knobby1 » Fri Apr 16, 2021 1:09 am
Lazam1985 wrote:Hi I have a Mk6 Ford transit
Loz
FWD or RWD..?? 5 or 6 speed..??
Postby Lazam1985 » Fri Apr 16, 2021 11:45 pm
Hi is 5speed front wheel drive
Issue is only with second gear and not that often might just be bad driving on my part but it is grinding more and popping out of second every now and then
Do you thinks it’s gonna be a good thing to change the transmission oil. (Been reading all these stories online about changing and flushing oil can cause more issues to a transmission on its last legs)
Lazam1985
Postby Altransit » Sat Apr 17, 2021 10:03 am
Before you blame the box itself, I would check the condition of the selector bearing, and also the cables, either of these could cause poor selection.
I had a loose bolt on the selector itself (on top of the gearbox) which was causing selection problems.
Postby richardstubbs » Sat Apr 17, 2021 10:00 pm
All the stuff above, but;
If the transmission is on its last legs then new oil won't make it worse, it just won't make it better. If, however, it's just got the wrong oil or no oil in it then it might well fix it or at least make it better for a while. I reckon it's always worth changing the oil, because oil is cheap and gearboxes are expensive. Mine had ATF in it when I got it - I changed it for the proper synthetic 75w-90 GL-4 and it no longer whines and crunches and changes gear fine now. Still jumps out of reverse sometimes though, but it's got 161k on it so I can live with that.
If it is broken it's probably easier to get a whole used gearbox.
2005 Mk6 85T280 Camper
richardstubbs
Postby Lazam1985 » Thu Apr 22, 2021 9:57 am
Thanks for the info
Will get the cables and selector bearing checked out too thanks
Lazam1985
