Mk7 2.2 RWD jumbo nightmare
Postby womble171 » Sun Apr 18, 2021 7:55 am
Morning guys.
Had a mare of a time with my mk7 62plate 2.2 rwd jumbo yesterday!
was on M62 heading up to Leeds when it conked out in middle lane. Managed to get over to hard shoulder and called RAC. After an hour or so, guy turns up an says it cant be fixed at roadside....didnt even try! An hour later a recovery truck turns up an says its too big to recover. Had to pay an independant to come an get me to the tune of £400!!
No warning signs or lights on dash, just lost power. All fluid levels checked before i set off, so not ran dry or anything.
Cant seem to turn the crank by hand, but want to rule out seized alternator before i cry some more.
How do you remove aux belt on 2.2 rwd? On my 2.4 it was just a bar straight into tensioner pulley, but this looks a different set up?
Secondly, what could cause the engine just to seize, or pack up out of the blue? Only code im getting on forscan is glow plug 3 fault, but ive had that since i got the van.
Any advice greatly appreciated as always....
womble171
Re: Mk7 2.2 RWD jumbo nightmare
Postby womble171 » Sun Apr 18, 2021 10:32 am
Update...
Took the aux belt off and everything free except crank pulley. Guess I'm looking at a new engine?
Anyone know and good source for engines, and does anyone know probable cause for the seizure?
I'm gonna whip the fuel filter off to see if there is any glitter in it.
womble171
Postby andz327 » Mon Apr 19, 2021 4:58 pm
Glitter would be in your oil filter,
Have you checked the timing chain hasn't snapped
Sent from my SM-G975F using Tapatalk
andz327
Postby womble171 » Mon Apr 19, 2021 6:50 pm
Took the casing off earlier and timing chain seems good.
I can get a bit of movement if I get a socket on cams, but crank is solid an won't budge.
womble171
Postby knobby1 » Mon Apr 19, 2021 8:53 pm
womble171 wrote:Took the casing off earlier and timing chain seems good.
Probably thrown a rod or torn piston and/or bearing.....no holes in the block..??
Postby Altransit » Mon Apr 19, 2021 9:06 pm
I may be wrong, but aren't these Euro5 2.2 engines prone to oil pump failure :?: :?
Postby knobby1 » Mon Apr 19, 2021 10:39 pm
Altransit wrote:I may be wrong, but aren't these Euro5 2.2 engines prone to oil pump failure :?: :?
I believe you are correct Sir. Mostly the FWD's though wasn't it...??
Postby womble171 » Tue Apr 20, 2021 1:44 am
Block appears good with no holes. I can see the oil pump on the chain, but I guess its not just a case of replacing that? Is there any way to test to see if it was the oil pump that has failed, at least I'll know what the cause was?
womble171
Postby knobby1 » Tue Apr 20, 2021 2:45 am
womble171 wrote:Block appears good with no holes. I can see the oil pump on the chain, but I guess its not just a case of replacing that? Is there any way to test to see if it was the oil pump that has failed, at least I'll know what the cause was?
Big end and main bearings along with the bores will have suffered first if the oil pump has failed. Most of the puma engines also have oil jets which squirt oil into the underside of the pistons and onto the bores.
Trouble is you can't get at the bottom end easily with the engine in the van. Ford in their wisdom decided to fit a "mid sump" stiffener plate to them which makes it rather difficult to get at all the gubbins in the bottom end from underneath.
http://www.catcar.info/ford/?lang=en&l= ... MysxMzM%3D
Might pay to check the cam bearing journals for stupid amounts of wear too, I suspect they don't like it when there's no oil about.
It's also possible that the oil pick-up in the sump has been blocked with crud....not unheard of....that would give similar symptoms to a failed oil pump methinks.
Postby womble171 » Tue Apr 20, 2021 3:06 am
Thanks for info mate, looks like it's a trip to a rebuild specialist!
Recommend any northwest area?
womble171
Postby knobby1 » Tue Apr 20, 2021 6:36 am
womble171 wrote:Thanks for info mate, looks like it's a trip to a rebuild specialist!
I'd be investigating what exactly has happened first....if the damage is only minor, it may be a relatively easy fix. If major damage is found, an exchange or recon engine may be the way to go.
Postby womble171 » Tue Apr 20, 2021 6:55 am
Is there anything else I could check for without having to take engine out?
I've not got the equipment to take it out unfortunately .
womble171
Postby Altransit » Tue Apr 20, 2021 9:08 am
In the event of no oil, I would think that the turbo would have failed fairly quickly, so you could check and see if there's a lot of float in the bearing :idea:
If the turbo is OK, it's possible that the engine may not be as bad as we think :)
Postby womble171 » Tue Apr 20, 2021 9:24 pm
Managed to get out and have another tinker.
The turbo has got a bit of play in, but impellers seem intact.
However, I can't say the same for bottom end! I managed to get the sump off, well of enough so I can have a look inside. I'm no master mechanic, but I'm pretty sure there is not supposed to be bits of metal in there? Feels like a gravel pit at the bottom!!
womble171
Postby andz327 » Wed Apr 21, 2021 12:17 am
Various ways to go but none are cheap , low miles 35k engine with everything including turbo and injectors would be best option but not cheapImage
andz327
