gsc1ugs wrote:What are cross pieces please? The prop shaft looks true? What does UJ stand for?
gsc1ugs wrote:I have a noise, bad vibrating noise hitting second gear a going into third gear it feels like something is going to disintegrate, engine and box are fine, i changed the prop shaft centre bearing thinking it could be that because it was a bit worn that did not solve it, ive shook the wheels to see if its a wheel bearing but im at a loss and vehicle can not go past 2nd gear speed, anything i can check over pls?
https://bfy.tw/RO55gsc1ugs wrote:What are the cross pieces?
https://drivesmartwarranty.com/car-center/resources/extended-warranty/drivetraingsc1ugs wrote:Questions still need clarifying sorry
"Cross pieces UJ" = Universal joints.
"then remove the tail shaft from the diff flange & turn the pinion by hand to see if it's smooth/rumbling or not."
Thxs
bambi mk 1 wrote:gsc1ugs wrote:I have a noise, bad vibrating noise hitting second gear a going into third gear it feels like something is going to disintegrate, engine and box are fine, i changed the prop shaft centre bearing thinking it could be that because it was a bit worn that did not solve it, ive shook the wheels to see if its a wheel bearing but im at a loss and vehicle can not go past 2nd gear speed, anything i can check over pls?
What makes you think the gearbox is ok can you select 3rd gear, have you tried to drive it in 4th gear
So the gearbox is glowing going downhillgsc1ugs wrote:I have took it out of gear rolling down hill which illuminates the gear box
Thxs
