I've been struggling with starting / battery woes for a while. Initially i thought it was just the cheap lion battery from ECP that was at fault, now i'm not so sure.
After multiple short journeys it's no surprise the thing needs a recharge however what i've been noticing is that after long drives (eg 20 miles) the engine would then struggle to restart and i keep noticing it. Yesterday we went out to an event appox 20 miles away, got back to van, it started but i was still aware that it wasn't sounding like a peak performance. Drove home.. This morning it was a bit slower to start. Went to work, finished, got in the van and it really struggled to start. Once running, things like headlights don't seem to be a problem - unless i'm just not noticing.
Got home, got the little'un to come out with the voltmeter before i stopped / charged the engine.. On the engine jump starting points there is 13.9V (well it fluctuates a little between 13.85-13.95V but it's enough to show an output). When i checked the battery, the voltage was 12.05V - yes 1.9V lower than the output voltage from the alternator across the engine.
So the alternator seems to be running but the power isn't making it back to the battery. Is there a charging relay somewhere that has to be turned on or something? - I'm fed up of keep connecting the charger to it each night.
