ukbrad wrote:How shafted was I, how much would you expect this job to usually cost. At £800 in total on a 2008 this has to go down as my most expensive MOT yet.
Transits are not cheap to run or maintain. Yes you may well have been done on your brake pipes but sanding them down and greasing them up doesn't always work. I have an old renault parked up which had corroded brake lines. They looked like it was just surface corrosion. When i dropped the rear subframe that corrosion was actually rot - the thing just disintegrated - no snapping, it literally just turned into pieces of dust. You can replace them yourself (which is what i did) but you need to have nerves of steel and practice making the pipe flares (not easy unless you're a mechanic doing it daily). You might want to get yourself a brake pipe flare tool for the future as mechanics can pretty much charge what they want for brake pipes and nobody really challenges them - it's safety critical! The problem now is you can't really go back and ask for your money back - it's done. You need to put it down to experience and move on with your life. Next time, SHOP AROUND!
2002 Mk6 2.4L T330 (Turbo) 90HP with Auto gearbox / clutch / shifter.
Also has a built in brown trouser momenter due to the novel rear suspension and a "this'll cost a lot to fix" thought generator
