by knobby1 » Sun Oct 24, 2021 11:39 pm
The connector in the picture isn't for the rear light clusters, so must be for the central locking, heated rear windows or wipers if fitted...?
For the clusters, get yourself a simple test light/screwdriver, turn indicators on, the wire that flashes will be for them. Then do the same for reverse, brake lights...parkers, fogs etc... It's just a simple process of elemination.
Use a multimeter to find the earth wire, it will have continuity to the body.
Another way is to follow the traces in the cluster to the relevant bulb and wire at the connector...an elimination process.
