Change Waterpump/Vacuum Pump Gasket
Postby Lifirth » Tue Oct 26, 2021 7:23 pm
Hi guys
I’ve an oil leak coming from the water pump/vacuum pump area, can anyone help with the steps to replace the gasket? How hard is it to do? I worry about taking the belt off..
Cheers!
Lifirth
Re: Change Waterpump/Vacuum Pump Gasket
Postby dumper » Tue Oct 26, 2021 7:50 pm
If it’s rwd and the leak is between the vac pump and water pump you can change it without removing the belt but if it’s at the block to pump leak you will need to drain the water/ belt off when I did my mk6 water pump I removed the turbo inlet pipe and the water pipes round it and it was easy to do not done a fwd or a mk7 it’s best if you put the exact model of van you will get more detail help . Before you start try and trace where the oil is coming from and that it is only a gasket and not the pumps themselves.
Postby knobby1 » Tue Oct 26, 2021 8:15 pm
dumper wrote:If it’s rwd and the leak is between the vac pump and water pump you can change it without removing the belt
I think the belt does have to come off as it drives the vac pump too. Mk6 and Mk7 2.4 RWD are similar setup.
Can't be a FWD as the vac pump is nowhere near the water pump.
Postby Lifirth » Tue Oct 26, 2021 8:19 pm
Sorry forgot to mention, It’s a 2009 2.4 RWD
Cheers!
Lifirth
Postby dumper » Tue Oct 26, 2021 10:05 pm
The. Mk6 2.4 you can remove the vac pump without disturbing the water pump to change the gasket in between belt only needs to come off to remove the water pump when I looked at the works mk7 it looked to be easier as more room at the top of the engine.
Postby andz327 » Wed Oct 27, 2021 12:02 am
What's the worry about taking a fan belt off ???? It's not as if it's a timing belt
Sent from my SM-G975F using Tapatalk
andz327
Postby knobby1 » Wed Oct 27, 2021 12:23 am
andz327 wrote:What's the worry about taking a fan belt off ???? It's not as if it's a timing belt
My thoughts exactly...TBH I can't see how you'd remove the Vac pump without taking the belt off..unless you want to break fingers etc...there's quite a bit of force on the tensioner.
Postby andz327 » Wed Oct 27, 2021 1:50 am
Who knows mucker
andz327
Postby dumper » Wed Oct 27, 2021 6:21 am
On my mk6 135 tdci the vac pump was bolted on the rear end of the water pump that’s why I’m saying that to work on the vac pump only you don’t need to touch the belt .
Postby Lifirth » Wed Oct 27, 2021 2:19 pm
Thanks!
Do I need to take the bumper off to get access to anything?
Lifirth
Postby dumper » Wed Oct 27, 2021 2:34 pm
I didn’t on the mk6 someone who has done a mk7 will no better.
Postby knobby1 » Wed Oct 27, 2021 8:02 pm
dumper wrote:On my mk6 135 tdci the vac pump was bolted on the rear end of the water pump that’s why I’m saying that to work on the vac pump only you don’t need to touch the belt .
Ummm....I don't think so..Here's the water pump for the Mk6 2.4 TDDi & TDCi and you can clearly see where the vacuum pump bolts "on top" of the water pump. Mk7 2.4 is the same.
http://www.catcar.info/ford/?lang=en&l= ... NCsyNzI%3D
Postby knobby1 » Wed Oct 27, 2021 8:10 pm
Lifirth wrote:Thanks!
No....the belt tensioner can be a bit of a pig if it's seized but can easily be done without removing anything major. Three bolts hold the vac pump onto the water pump, don't over tighten them when refitting, the thread in the water pump is only aluminium. There's two types of gaskets too, one with moulded O-rings and one without...the water pump will determine which is required.
Here's an exploded view of the vacuum pump and the gasket between it and the water pump.
http://www.catcar.info/ford/?lang=en&l= ... I3Mg%3D%3D
Postby knobby1 » Wed Oct 27, 2021 8:13 pm
dumper wrote:I didn’t on the mk6 someone who has done a mk7 will no better.
Mk6 & Mk7 2.4 vac/water pumps are essentially the same.
Here they are bolted together..:
Postby dumper » Wed Oct 27, 2021 9:25 pm
Your right knobby I’ve got it wrong could have sworn it was on the rear must have been thinking of a different vehicle old age must be creeping up on me :lol: but in my defence it must have been the best part of 10 years ago .
