dumper wrote:If it’s rwd and the leak is between the vac pump and water pump you can change it without removing the belt
knobby1 wrote:dumper wrote:If it’s rwd and the leak is between the vac pump and water pump you can change it without removing the belt
I think the belt does have to come off as it drives the vac pump too. Mk6 and Mk7 2.4 RWD are similar setup.
Can't be a FWD as the vac pump is nowhere near the water pump.
andz327 wrote:What's the worry about taking a fan belt off ???? It's not as if it's a timing belt
Sent from my SM-G975F using Tapatalk
dumper wrote:On my mk6 135 tdci the vac pump was bolted on the rear end of the water pump that’s why I’m saying that to work on the vac pump only you don’t need to touch the belt .
Lifirth wrote:Thanks!
Do I need to take the bumper off to get access to anything?
dumper wrote:I didn’t on the mk6 someone who has done a mk7 will no better.
Users browsing this forum: Yahoo [Bot]
