Good evening and thank you in advance for any help.
I bought my 2.2 mk7 9 seat bus middle of last year with no faults however it had been sat for a while. And since about 2 months of owning it faults started to appear.
The crank pulley started squeeling, ive ordered a new one
Drive shaft seal is leaking a little, ive ordered a new one.
Heres where it gets interesting:
At first the central locking was hit or miss and the interior lights went dim. I changed the front battery and everything seemed ok.
I ran a bluedriver obd and it pulled up these codes:
U0401 - invalid data recieved from ecm/pcm "a"
B1238 - center module code
B1d19 - center module code
B13d3 - remote keyless entry code.
I reset these codes and continued on my way in novemver
Over the past few 6 weeks things have started to develop;
Chugging idle when cold
Rev needle intermittently going out
Speed needle intermittently going out
Speed needle sometimes fluctuating
Trip counter randomly resets (when ignitions off)
So ran another scan:
C1a94 - front right wheel speed sensor short or ground
U0401 - ecm pcm invalid data signal a
Cleared, did a long drive
New codes;
C1a94
U0401
P0623 - gen lamp control circuit
B1318 - battery voltage low
Tested both batteries for resting, charging and voltage drop and all seem fine.
All weird symptoms are still happening.
Has anyone got any suggestions?
