Boonjason wrote:Can anyone confirm if the engine drops 2 piston ring the engine will not start and the oil light would be on cause there would not have any oil presure only asking as someone took there truck to a garage theve told I'm is fuel pump had gone that cost £675 then he told I'm that is injectors where no good cost £900 now he's been told it's dropped a couple of piston rings it starts up but it doesn't sound good like the timing is out but I don't want to touch it in case I end up getting the blame and end up in court thanks for any advice just trying to help this bloke out
Boonjason wrote:Hi knobby1 mate the engine is no good starting from cold sounds very rough then soon as it gets hot it cuts out and locks up and struggles to turn over all the injector seals have been checked and are all good someone says it may of dropped a couple of rings so just got a replacement engine to go in it and don't fancy a cheap recon engine with cheap sh*t parts that's going last 5 minutes
Boonjason wrote:Hi knobby1 mate it's had a brand new starter motor new batterys it starts when cold won't tick over right and cuts out when hot and the engine struggles to turn over after that so the owner looking for another engine as he doesn't want spend anymore money on that engine and I don't want get the blame and end up in court mate thanks for the info though much appreciated thank you mate
ginsambo wrote:Probably wrong but I got advice on probably the pump gone wrong after I replaced SCV and PRV and had similar symptoms, although I did have massive diesel knock on cold start and white/blue smoke when cold and it cut out when hot. No fault codes or lights. Fuel pressure was insanely high. Had no idea the ecu could go that wrong or seemingly adjust to failing components without so much as a fault code or a warning light. All got solved. What does engine locks mean? How long after stalling warm will the engine restart and does it start from cold fine?
knobby1 wrote:ginsambo wrote:Probably wrong but I got advice on probably the pump gone wrong after I replaced SCV and PRV and had similar symptoms, although I did have massive diesel knock on cold start and white/blue smoke when cold and it cut out when hot. No fault codes or lights. Fuel pressure was insanely high. Had no idea the ecu could go that wrong or seemingly adjust to failing components without so much as a fault code or a warning light. All got solved. What does engine locks mean? How long after stalling warm will the engine restart and does it start from cold fine?
When you replaced the SCV and PRV, were the learns done..??
Lrd Knobrot
ginsambo wrote:Not completely sure mate. They said fuel pressure was off the scale and adjusted it, are a good injection specialist so presume they did they learns as I wrote down what I'd done and hadn't but didn't ask. Can you relearn a learn at any time to be sure? Would have done it myself, but was convinced it was f@@ked, so didn't bother. Turns out in the end I'd 98% fixed it.
