TheCake wrote:Not sure how good those autels are with fords but the go to on here is forscan and a modified elm-327 reader as some other readers may not pick up all the codes.
As for the air in system it could be coming from the fuel return pipe most likely the little green o-rings on top of the injectors.
What was fuel rail pressure reading on crank and running?
TheCake wrote:Try starting when fed from a can bypassing the filter if that works you've likely got a bad seal somewhere around the filter.
Check the hoses for any wear/cracks/holes
Genuine ford filter? Original filter housing?
Rail pressure looks good.
Peteb71 wrote:TheCake wrote:Try starting when fed from a can bypassing the filter if that works you've likely got a bad seal somewhere around the filter.
Ive recently changed the Filter housing and filter together with the Filter to pump opaque pipe and the return black return pipe which were all Genuine Ford. The other two pipes (return to tank and tank to filter) are still original but don't seem to have any noticeable
air bubbles entering from tank supply or exiting the filter To Pump. Ive now disconnected the priming hand pump tool after no bubbles were present when running.
If the rail pressure looks good on cranking wouldn't that indicate a good air free supply? (apologies if this is a stupid question i just trying to understand the workings)
tranmx2 wrote:Comparison 2012 2.2 DRRB 100 HP RWD - Forscan readings.
19 03 22 Forscan.
Cold start.
Pre cranking.
FRP 280 kpa. 2.8 bar.
DPF 0.1 kpa.
MAP 100 kpa.
Crank no start.
FRP 40660 kpa. 406 bar.
DPF 0.0 kpa.
MAP 100 kpa.
Crank start.
FRP 25720 kpa. 257 bar.
DPF 1.1 kpa.
MAP 99.3 kpa.
Peteb71 wrote:Another update
Purchased Forscan as recommended and read some live data
Do these look ok?
Should there be rail pressure before being cranked over as mine is reading 0.0kpa?[color=#8000FF][/color]
Peteb71 wrote:Thanks for the input. Much appreciated
I’ll take the egr off and inspect it. Do you think this could then be the cause of why it will only start with easy start?
Strange if is stuck open that it hasn’t brought on the eml or a DTC
