Hello
Has anyone got a diagram of the wiring loom into the passenger door from the BCM please? The passenger door was working fine on Wednesday night i locked up and the next morning the door will no longer open and is deadlocked shut. You cant hear the lock trying to move either lock or unlock when you press the key fob so chances are the locks died but before i chop the van door up to get it open i just wanted to test the loom into the lock to see if there's not something silly like i wire broken.
Also if i have to cut the lock off to open the door has anyone got any tricks for least possible damage? i was thinking going through the pillar where the sliding doors shuts to and drilling the bolts out from behind and opening the door with the D part still in the lock.
Thanks for any help!
