5h4ggy wrote:Check the battery, mine did this. The battery was holding volts and charge but had a load test done and it was poor. Battery sorted
125 T 350 LWB 2003 *dead*
100 T 300 LWB 2002 *dead*
115 T 350 Trend Lwb 2011 *gone*
140 T 280 GLX MWB 2008
5h4ggy wrote:Just a thought, 1 of the pulleys isn't seized? Or seizing Making it really hard for the starter to turn?
5h4ggy wrote:It's very odd, only reason I suggest is had a rwd 2.4 and the vac pump started to seize and the van did a much less extreme version of what your seems to be doing, once started it was fine, I didn't realise it was seizing to I carried on using. And then is propper seized and snapped the belt. Just thinking of the easy stuff to check.
I also had the main starter fuse blow on a van, that's under the seat it's like 350amps or something daft, I was stranded and swapped it out for a bit of metal I had in the van. The metal also gave me that kind clicking and then It started. The metal obviously wasn't a good enough conductor. So maybe have a look that to maybe a bad connection and the little extra load need in the morning for a cold start is making the fuse or a connection throw a wobbly
5h4ggy wrote:Has your van got 2 batteries or 1
andz327 wrote:Probably the the ignition switch, if your decent with the spanners take the starter out and strip the starter(2× Phillips screws, 2x 8mm or sometimes 7mm long bolts and 13mm nut )and check the brushes as they can give same symptoms, clean it all out lube the little planet gears , if it needs brushes you can get off ebay for about £20, if brushes ok just a clean and lube makes big difference
Sent from my SM-G975F using Tapatalk
Mr_Viking wrote:hi all i have a mk7 t260 2008 euro 4 2.2 tdci 140ps
In the morning when you try to start it its like the battery is being disconnected while cranking( dash lights, interior flicker on/off) And starter clicks like low battery also if i let the glow plug light go out then turn the key it doesnt crank at all.
but once its started its starts all day no problems.
Checked all fuses, relays, cleaned earth points, have ordered a new ignition switch as thats my suspect.
Plugged it in and no dtcs
Any other ideas?
tranmx2 wrote:Starter solenoid contacts dirty. Supply to starter solenoid interrupted.
if i let the glow plug light go out then turn the key it doesnt crank at all. Glow pug supply could be on a timer, can be a bimetal switch. Battery drained - could be direct earth on glow plug circuit.
Make / break in circuit - eg wire on solenoid touches - gets warm - moves away. Vibration can cause make/break in circuit. Is damaged part of circuit can be supply or return. Corroded earth can cause this symptom.
