Dear Transiteers, First Post please be gentle
I have what I believe to be a MK6 2.4 Duratorque engine in my TX2 taxi and I have had a lot of oil in the water. When it "broke down" I think it must have overheated and steam came from around by the heater matrix and grey sludgy water.
I have taken the gamble to replace the the oil cooler gasket as I have read that that they are prone to failure but I'm not sure that this is the cause. I have tested the water side of the cooler by using compressed air and there aren't any leaks on the oil side The plan is not to connect up the water connections (just bypass them) clean out all of the gunge out of the water system.
So the question is if it isn't the cooler then what might it be? The Taxi is a 2006 model and the engine is definitely 2.4 and the oil filter is replaceable paper element.
Any help appreciated - thanks in advance
Barry
